white smoke?
Old Sep 11, 2007 | 07:29 AM
dalkins1's Avatar
dalkins1
white smoke?
I have a 97 psd with 230k, 5spd,,,,,Just bought it 3 weeks ago. Noticed when I first start it in the mornings it will white smoke briefly. What does this mean, it runs great so I am thinking its just alittle worn out? Also when running it through the gears if I get rpm's up to about 2500-2800 it will black smoke when I am stepping into it. Thanks for info
Old Sep 11, 2007 | 07:39 AM
Neal 97 250's Avatar
Neal 97 250
White smoke is usually caused by a glow plug not working. Mine does the same thing and I have 1 bad. No problem at all. Will run great forever. As far as the black smoke it is usually caused by a chip or different injectors installed which is a good thing. The 10K mod will cause it to do it also. Basically when you have black smoke when you are getting on it is a good thing. More smoke = more power.
Old Sep 11, 2007 | 10:34 AM
dalkins1's Avatar
dalkins1
Thanks Neal,,, I am new to diesels and want to make sure things are going good with it.
Old Sep 11, 2007 | 12:09 PM
Neal 97 250
No problem. Sounds like the truck is in good condition. Let us know what you want to do to it and we can help. You can check to see if there is a chip in it by removing the emergency brake (3 bolts) and looking at the back of the pcm.
Old Sep 11, 2007 | 12:30 PM
Dustball8504's Avatar
Dustball8504
The 97 I had would also puff a little white smoke when would first start up and it ran fine for me with 250k on it. However, my 97 would also puff a little black smoke with just a 4inch straight pipe on it and nothing else done to it. It was bone stock when I bought it. Enjoy your truck, I regret getting rid of mine everyday.
Old Sep 11, 2007 | 03:56 PM
bkcowboss's Avatar
bkcowboss
Dont let your bad GP sit to long, when the don't cycle they get carbon build up, and over time element can get big enough with carbon that it will not come out the hole, some will even break the element off inside the cylinder when trying to extract it and they will have to fish it out another way. This is something that doesn't happen quick but will happen
Old Sep 11, 2007 | 09:18 PM
Neal 97 250
Thanx for the heads up black cow. I plan on doing all of mine when I do the II's great info though I never thought of that
Old Sep 11, 2007 | 09:28 PM
wreckit72's Avatar
wreckit72
Neal thats sounds like a good excuse to do the II's now.
Old Sep 11, 2007 | 09:29 PM
c00nhunterjoe's Avatar
c00nhunterjoe
you need no excuse when it comes to more power :P
Old Sep 11, 2007 | 09:40 PM
Neal 97 250
you do when it comes to the cash and add in the wife factor.
Old Sep 11, 2007 | 09:47 PM
c00nhunterjoe
well cash is no excuse,just a setback. the wife however is a dam good one
Old Sep 11, 2007 | 10:06 PM
Neal 97 250
You got one too, you know what I mean
Old Sep 11, 2007 | 10:26 PM
wreckit72's Avatar
wreckit72
Don't all wives need to be convinced that mods are necessary?
Old Sep 11, 2007 | 10:41 PM
Aireeek's Avatar
Aireeek
Lets see.....boob mod...... face make up mod......
Old Sep 12, 2007 | 07:53 AM
Neal 97 250
Wish we had an attitude mod...
