flat head V8
Old Sep 10, 2007 | 09:26 PM
fowler9693's Avatar
fowler9693
flat head V8
Looking at a couple of early F1 trucks. Any comments on the fuel consumption of the flat head V8s. Are these realistic daily drivers?
Thanks
Old Sep 10, 2007 | 09:48 PM
kooper909's Avatar
kooper909
Fit it with an overdrive, and I would think they should get about 20 on the highway, in stock form. Hopefully a flathead expert can jump in and clarify.
What I do know is that their sound is unbeatable, and if you build it right, it will be reliable and stand up to years of service.
Old Sep 10, 2007 | 10:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1
There are a couple of people on here who really use their flatty-powered trucks as daily drivers, and with good succes. (MTFlat for one) . To get away with that, you need to keep up with maintenance, which is not insignificant. Proper gearing helps a bunch. An OD is not in the cards without major surgery on Bonus Builts (48-52) because of the rear crossmember. Changing the rear axle to a 3.25 or 3.50 is a good compromise and a lot easier. There are other considerations to driving anything 55 yrs old on a daily basis, but I hope to get close to that shortly. Maintenance is so much easier and cheaper than on a newer car/truck that it is worth the sacrifice. Mileage is generally 14-16 mpg, nothing to crow about, but not the whole story as far as total cost/mile...
Old Sep 11, 2007 | 06:46 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Thanks
Yes they are realistic as far as gas mileage but I'd be more concerned about finding parts when something like a fuel pump, water pump, generator, voltage regulator, starter, fan pulley bearing, or even a 6V battery goes. You can't just walk into your local parts house and get this stuff off the shelves. A lot of parts can be had within a few days, however.
Old Sep 11, 2007 | 08:09 AM
rcav8or's Avatar
rcav8or
If you use it, SUPPORT IT
Flattie sound
How true, on the sound - I called a guy who was looking for a flattie, to see if he was interested in buying mine...he was putting one together, to put on a stand in his garage - no truck/car, just the stand - so he could hear it purr every now and then!
R
1951 F2
Pappys53
Apr 25, 2014 04:16 PM
Brettzky
Flathead V8 & Flathead 6
Oct 27, 2013 10:11 AM
olered53
1947 and Older Ford Trucks
Nov 30, 2005 08:00 PM
tcw
Jan 6, 2003 09:27 PM
52panel
Apr 16, 2002 06:32 PM
