Ground points
Old Sep 10, 2007 | 08:04 PM
PSKSAM2's Avatar
PSKSAM2
Ground points
I'm trying to electrically bond some of the body/bed/frame to improve my HF/VHF antenna performance. Has anyone found any good points on the bed to do this? I found the cab to frame ground straps and beefed them up a good deal, but I haven't found similar ones for the bed.
-Jim
Old Sep 11, 2007 | 01:39 PM
wendell borror's Avatar
wendell borror
Just get one of those grounding kits off of ebay, they have like 8 or so different grounding points with heavy gauge wire, shouldn't need anymore than that. The kits are pretty cheap as well.
Old Sep 11, 2007 | 10:09 PM
PSKSAM2's Avatar
PSKSAM2
I make my own ground straps. Far cheaper and I know they work. I was just wondering if anyone knows of any good ground screws on the frame/bed. By good ground screw I mean 1) not a structural/suspension screw and 2) electrically grounded.
-Jim
Old Sep 12, 2007 | 06:41 AM
wendell borror
It wasn't so much that you can't make your own, the kits have instructions on the best grounding locations. Maybe someone can help you, but grounding hasn't been a problem for most of us, at least it doesn't come up. Good luck and hopefully someone will have some advice for you.
Old Oct 17, 2007 | 02:51 PM
irvinf's Avatar
irvinf
Checkout this web site www.k0bg.com
Old Oct 17, 2007 | 03:14 PM
fordboy_52's Avatar
fordboy_52
i ran a 12 guage wire from my neg terminal to my antenna..... it helped a little
Matt
