MOPAR coolant ok?
Old Sep 10, 2007 | 04:10 PM
RedStroker6's Avatar
RedStroker6
MOPAR coolant ok?
since i'm in a situation where i can get MOPAR green collant for cheap/free, would that be ok to use in my 95 making sure the SCA's are good? the truck needs a flush and i've got access to all the goodies....
edit: actually, its "federated" green, but we use it in mopars...
Old Sep 10, 2007 | 04:28 PM
tjbeggs's Avatar
tjbeggs
if its green then its the same as all the other green coolant out there and you will be fine as long as you put additives in it.
Old Sep 10, 2007 | 05:19 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Like TJ said, as long as it's an ethylene glycol based coolant and you use the additives your good to go.
