Sponsored by: Real Truck
PWR steering loss
Old Sep 10, 2007 | 04:00 PM
Edkajo's Avatar
Edkajo
PWR steering loss
First, this is a 03 f350 w/7.3.
I lost power steering breifly at idle today. The issue started on an off ramp and lasted about 15min in stop a go traffic. Power would resume once the rpm's increased slightly. I drove about 50 more miles ( highway and city) and it's been fine at idle since. It's hard to tell what may have caused it when it's working OK at the moment.There were no unusual noises but it seems like I've noticed a very slight vibration in the past week or so.
Anyone with a similar experience? Any suggestions will be appreciated.
Old Sep 10, 2007 | 06:23 PM
zx250's Avatar
zx250
Of the next Riffraff East
Check you Power steering pump resoivor. Remember it uses ATF. The pump also supplies boost to the master cylinder for the brakes. If you lost power steering you probably lost brakes also. Did the power steering fail only when you applied brakes? If so, then you are low on ATF or you may have a failing pump.
Old Sep 11, 2007 | 12:08 AM
Edkajo's Avatar
Edkajo
When I realized the steering was out on the coast up an off ramp I thought the truck stalled or another hyroboost line blew but the brakes were fine. No leaks anywhere. Guess I should start with the pump then. Probably weak. Thanks.
Mike SVOR
6.4L Power Stroke Diesel
Nov 26, 2013 08:54 AM
mr.fordneck
Apr 24, 2012 08:17 PM
LTBeck41
Bronco II
Mar 30, 2008 07:59 PM
ShortboxF150
Aug 31, 2007 03:04 PM
Trampus
1978 - 1996 Big Bronco
26
Oct 5, 2003 06:30 AM
