Bronco II Ford Bronco II
Steering Wheel Crooked
Old Mar 26, 2008 | 09:22 PM
LTBeck41's Avatar
LTBeck41
Exclamation Steering Wheel Crooked
Steering wheel was way WAY out of align after I changed power steering gear (like 90 degrees). Alignment and addition of totally missing right side radius arm bushings left it out of alignment with steering wheel top at about the "two o'clock" position to the right.
Pitman arm has skinny and fat splines so I cannot just shift it slightly only in large moves. These appear to be to large.
Pulled the steering wheel and found that the damn thing is keyed instead of splined!
Any suggestion on how to get the steering wheel straight again? Daughter is trying to learn to drive and keeps swerving INTO traffic!
Old Mar 27, 2008 | 08:29 AM
5.0B2's Avatar
5.0B2
The connector shaft between the Steering box and the rag joint (under the plastic collar) is splined.
Old Mar 30, 2008 | 05:30 PM
LTBeck41's Avatar
LTBeck41
Under hood the shaft to steering gear connection is D shaped. Moving up the shaft towards the firewall, the next connection (right above the rubber thing) is square. Is there another connection inside the cab, between the firewall and the actual steering wheel?
Can the steering gear be adjusted? Looks there is an adjuster on top of it.
Old Mar 30, 2008 | 07:59 PM
tbolt 460's Avatar
tbolt 460
the shaft is splined. you can put the wheel where ever you want.
AZ48
Jan 30, 2014 11:24 PM
Sharky146
Sep 6, 2010 09:13 AM
44dwarf
Dec 10, 2009 06:20 AM
jimkari
Dec 26, 2007 11:42 AM
