Replacing plugs at 100k?
I used wd-40 and soaked for 2 hours. the plugs still came out very slow.
here is a couple links: one is the TSB for changinging and what to do if you have thread or broken plug issues, the other is a video on changing the plugs.
https://www.ford-trucks.com/tsb/fulltext/show_article.php?tsb=06-15-2
http://flatratetech.com/index.php?categoryid=12
The penetrating oil though is a good tip no matter which plugs you have.
I watched the Vid on the 5.4l 3V plug change. If I was Ford I would change that plug/head design in a hurry. You shouldn't have to worry about spark plugs breaking off in the head.
