How Serious Is This?
Old Sep 9, 2007 | 06:09 PM
alwayssomething's Avatar
alwayssomething
Exclamation How Serious Is This?
MY FORD EXPEDITION EDDIE BAUER 99. HAS STARTED TO MAKE A SHORT VIBERATING NOISE AFTER REACHING 40-45 MPH THEN IT STOPS. IT ALSO FEFUSES TO SHIFT INTO GEAR WHEN GOING UP STEEP INCLINES. CAN SOMEONE TELL ME WHAT THIS COULD BE AND HOW DANGEROUS THIS IS. THIS IS OUR FAMILY VEHICLE AND I HAVE 3 SMALL CHILDREN ALL UNDER 4.
THE FORD DEALERSHIP SAID IT WAS THE FUELPUMP AND REPLACED IT. IT IS STILL DOING THE SAME THING. THEY PRETTY MUCH TOLD ME THEY DON'T KNOW WHAT IT IS NOW(THEY ASSURED ME IT WASN'T DANGEROUS). I'M SCARED IT'S GOING TO LOCK UP AND WERE GOING TO WRECK. I HAVE TO DRIVE MY CHILDREN IN IT. I HAVE NO CHOICE OUR CAR WILL NOT FIT 2 CAR SEATS AND INFANT CARRIER. PLEASE HELP!
Old Sep 9, 2007 | 08:29 PM
dakota_viking's Avatar
dakota_viking
Is your check engine light coming on? To me it almost sounds like your torque converter is not locking up/kicking down when it is supposed to or you have a shifting problem in the transmission.
Either way, it isn't dangerous unless you are trying to merge into heavy traffic.
How many miles are on it?
If a Ford shop can't figure it out, you may want to take it to a good transmission shop before winter and see if they can diagnose the problem.
Around here,( N.E. Oklahoma ) they usually charge around $1800 if they have to remove and rebuild the transmission. You may get lucky and it may just be a filter and fluid issue.
Good luck and if at all possible, for the families sake, have it checked out soon.
Take care,
Tim
Old Sep 9, 2007 | 08:43 PM
alwayssomething
Thanks For The Response! No Check Light Engine Coming On. 75,000 Plus. I'll Look Into Finding A Good Transmission Shop Here In Ohio. Thank You!!
Missy
Old Sep 9, 2007 | 08:52 PM
Scriv's Avatar
Scriv
Sounds to me like it could also be a stopped up catalytic converter, you might want to check on that too.
Old Sep 10, 2007 | 09:32 AM
alwayssomething
Wink
Thank You! I'll Check Into That Also.
55 f350
General Automotive Discussion
Aug 15, 2010 06:18 PM
lariat97
Arkansas Chapter
Sep 28, 2008 08:21 PM
lariat97
Chapter Meets Planning
Sep 20, 2008 01:37 PM
Oval_obsessed
27
Nov 17, 2006 11:33 AM
pfogle
35
Aug 29, 2003 12:58 AM
