Sputters just off idle.....
Old Sep 9, 2007 | 03:57 PM
RocknXJ's Avatar
RocknXJ
The engine started dying occasionally just off idle, like when coming to a stop, taking off or going around a slow corner. It also sputters now and then when taking off under light throttle. I programed the Edge back to stock and it went away, but now it's sputtered a couple of times, again just off idle, with the stock tune. So, I'm wondering what might be causing it, something that the chip makes worse.
There are no codes now. I just had it in the shop to get new glow plugs installed, and they also replaced the backpressure sensor and the intake air temp sensor which had bad readings. I was hoping that maybe something there was causing it but no luck, it's still doing it.
Any ideas? TIA
Richard
Old Sep 9, 2007 | 04:03 PM
jboard's Avatar
jboard
Have you changed your fuel filter lately? That will deffinitely cause this. But there could be some other things. If you change it drin the fuel water separator when you change it, And spray some brake cleaner on the little screen that is toward the top of the inside of the housing. Its between the housing and the fuel regulator, it tends to get clogged with crap. When you do all that fill the filter canister full of sea foam when you install the new filter.
-----------Jeremy
Old Sep 9, 2007 | 04:05 PM
caseydudem's Avatar
caseydudem
Cps
Have you tried replacing the CPS. Those symptoms seem to fit a CPS going bad. For only about thirty dollars might be worth just trying to see what happens. Hope that helps
RocknXJ's Avatar
RocknXJ
Fuel filter gets changed every other oil change, but I haven't checked it.
Old Sep 9, 2007 | 04:06 PM
RocknXJ's Avatar
RocknXJ
Yeah, I put in my spare CPS last week and it didn't make any difference.
Old Sep 9, 2007 | 04:11 PM
jboard's Avatar
jboard
I had a problem with that little screen myself needless to say it isnt there anymore....lol...I would check it if i was you.
-----------Jeremy
caseydudem's Avatar
caseydudem
OKay next guess
To go along with the fuel filter change to clean the fuel screen. Those can get really dirty really fast, but thats just a shot in the dark.
Old Sep 9, 2007 | 04:12 PM
caseydudem's Avatar
caseydudem
Too fast for me Jeremy
Old Sep 9, 2007 | 04:16 PM
jboard's Avatar
jboard
Haha it happens I started typing the first post and when I submitted it there were already 3 posted...lol
--------------Jeremy
Old Sep 9, 2007 | 04:29 PM
RocknXJ's Avatar
RocknXJ
So, fuel screen can cause it to sputter or die at slow speed? It runs perfect the rest of the time.
Old Sep 9, 2007 | 06:43 PM
jboard's Avatar
jboard
Its either that or I did have some others too. its just the easiest to do first. I also had my ICP sensor not working right and that had similar effects. And IPR o-rings could cause some of it too. Someone else will have some more info on it.
----------Jeremy
Old Sep 9, 2007 | 07:29 PM
bkcowboss's Avatar
bkcowboss
I have had the IPR cheap brass nut come loose and cause symilar symptoms, it is on the back of the HPOP
Old Sep 9, 2007 | 09:11 PM
1997F-350's Avatar
1997F-350
sounds like an oil problem.
Old Sep 10, 2007 | 06:04 AM
jboard's Avatar
jboard
The problem is that there are so many factors that can cause this thats what makes it so difficult to diagnose.
--------Jeremy
Old Sep 10, 2007 | 08:26 AM
Action4478's Avatar
Action4478
Any ideas? TIA
Richard
Get some real time data ,,,You'll be able to narrow it down...
