289-Flexplate-starter-help:)
Old Sep 9, 2007 | 01:04 PM
3Mike6's Avatar
3Mike6
I need to install a 289 ('66 engine) hooked to an AOD ('93 tranny), from what I've read I need to use the 28ounce flexplate...is there a 28ounce flexplate that comes in the 154? AND 163? tooth versions so I can run a starter from a 5.0?
See, I have a 5.0/AOD from a '93 Cougar, but have to run the 289 for a bit before I switch in the 5.0...so I'm trying to buy as few parts as possible just to get this truck moving under it's own power with the 289.
Did I confuse anyone yet?
Old Sep 9, 2007 | 04:57 PM
ken75ranger's Avatar
ken75ranger
Here's one that will work.
http://store.summitracing.com/partde...2&autoview=sku
Basically you need a flexplate for an AOD or C-4 tranny with 164 teeth and 28 oz balance.
If you want to do some junkyard shopping-
You can find an pre 1981 302 or 351w flexplate for a c4 it will work. You can also look for a 351w flexplate with an AOD.
Old Sep 9, 2007 | 06:17 PM
3Mike6's Avatar
3Mike6
Great info!
Thanks!
Holehawgg
21
May 27, 2012 10:34 AM
GreatNorthWoods
27
Apr 25, 2011 12:53 PM
dotcentral
Dec 28, 2009 05:07 PM
linckeil
Apr 27, 2006 08:46 PM
ronclark
Feb 24, 2005 07:05 AM
