how easy is it?
Old Sep 9, 2007 | 01:06 AM
blueranger103's Avatar
blueranger103
how easy is it?
how easy is it to take out the radiator support on a 1990 2.9L ranger mine has a big dent in the headlight socket and my light is crooked i want to replace it. what steps do i take? thanks
Old Sep 9, 2007 | 02:20 AM
smithc185's Avatar
smithc185
to remove radiator support you should just have to remove the top bolts and the bottom bolts and it should come loose. I have not YET done this on any of my trucks being most of my incedidents have been rear end damage. But every honda' or any other vehical i have had this issue with. The radiator core support can be tanken out with 4 bolts and you can replace with a new or used one.
Old Sep 9, 2007 | 02:23 AM
smithc185's Avatar
smithc185
but if i am thinking correctly a few beers talkin here the headlight assemblys are not a part of the radiator core support.
Old Sep 9, 2007 | 02:43 AM
blueranger103
but i believe they are affected by the radiator support? the harnesses for the headlights i think sit on the support and its all damaged in there. the previous owner hit something hard enough to dent it in about 2 in or so. but the main thing is that its just drop in and out. not that hard mabye an hour to do it fixing the head lights etc?
Old Sep 9, 2007 | 09:46 AM
ranger1999 Bob's Avatar
ranger1999 Bob
those pieces are weld in and they have to be cut out. and new ones welded in. is there any way you can clear the area of all the wiring and all and use a hammer and dolly to straighten it enough tomake the headlight straighter?
Old Sep 9, 2007 | 01:17 PM
blueranger103
there is not enough clearance in there to get much power on the hammer. ive tried are you sure they are weld in? what should i do?
Old Sep 9, 2007 | 08:27 PM
fyre82's Avatar
fyre82
Tear it down, get a spot weld cutter from Harbor Freight for 5$, cut out the welds and replace with a straight one. You will probably have to separate the front body mounts to get it all the way out.
I just ordered two spot weld cutters to tear apart the 88' parts rig I have in my yard. It's to darn dry to use a torch or grinder and I don't want another Moonlight fire starting in my back yard!
