Oil & Lubrication
Green Grease?
Old Sep 8, 2007 | 11:39 AM
77f2504by4's Avatar
77f2504by4
Question Green Grease?
Anyone out there use green grease, the stuff they use on speed tv? is the cost justified? its like 8 bucks for a tube of the green stuff, and 2 bucks for the stuff ive used for years. what are some of your thoughts?
Old Sep 9, 2007 | 12:59 AM
aurgathor's Avatar
aurgathor
Amongst others, marine grease may often be green. I did have some turquoise grease (Slick50, non-marine) and it wasn't much better than the regular stuff. Depending on the use you may need different greases, but for automotive use, one usually want a grease with moly in it. Unless they can show with some hard data that it is really better than the regular stuff, I wouldn't buy it for $8.
Old Sep 10, 2007 | 03:37 PM
jimandmandy's Avatar
jimandmandy
Ford recommends greases with moly. They will always be dark, almost black in color.
Jim
Old Sep 10, 2007 | 04:07 PM
stormyrider's Avatar
stormyrider
To get the most benifit from the moly, it needs to be at least 3%. Some have moly but not enough to do much good. Also moly doesn't play well with bronze bushings so avoid using it on bronze alloy bushings.
Old Sep 19, 2007 | 10:53 AM
69-highboy's Avatar
69-highboy
Here are two greases that I like and use the most: Delo blue #2, and Hydrotex #2 white. Just try washing them off your hands! Both contain a "tacky" element and have given good service in wheel bearings, trailers, 5th wheels and drive lines.
Old Sep 21, 2007 | 08:10 AM
kotzy's Avatar
kotzy
stormrider,please explain the moly deal with bronze bushings. Never heard that before, would like a little insight. Thanks. kotzy
Old Sep 21, 2007 | 10:01 AM
stormyrider
I attended a seminar put on by our lubrication supplier and Detroit Ball Bearing. The Molybendemdisulfide additive is a mined mineral that when added to grease is supposed to plate out on steel surfaces filling in the microscopic holes and making it more slippery. The steel is harder then the moly so it works well and is a benifit in applications where the grease has a tendency to washout, like on excavators that use steel bushings around the bucket area. But on applications where bronze bushings are used the moly is the harder item and actually acts like a fine abrasive and eats up the bronze bushing. If it is steel on steel moly is a good additive. There is even a company making a moly additive for mineral oil lubricated gearboxes and has been used on engines, although I am suspecious of its reaction with the babbit on the crank & rod bearings. Would need oil analysis to check on that.
Old Sep 21, 2007 | 05:29 PM
kotzy's Avatar
kotzy
Storm Thanks that makes sense and may be fact. I was told the particals are so small and that is what made it suspendable in gear oils. We used it in manual gear boxes with bronze bearings on the counter shafts, and we also greased chassis parts with moly grease. This is a new slant I never heard before, or someone came up with an alternative and trying to sell it. Anyway, when everyone thinks the same no one thinks much, you have given me something to ponder. Thanks again. kotzy
Old Sep 22, 2007 | 08:38 AM
pawpaw's Avatar
pawpaw
Moly loaded lubes in gear boxes with (yellow metal) bronze gears or bearings isn't rcommended either.
So we need to be careful of the lube recipe we use on ALL of our equiptment.
Moly under heat & pressure, doesn't react well with yellow metals, so don't use a moly loaded lube on such.
This after I talked to a lube engineer at Chevron, about a straight weight lube for my old JC Penny tillers gear box, which specified a straight weight 140 gear lube, for it's bronze worm gear & I couldn't find a small contaner of straight weight GL-1 lube anywhere!!!!
He recommended their straight weight 460 lube, but I can't find it in anything less than a 60 gallon drum!!!!! lol
Anyway we need to be mindful of the lube specfications our manufacturers affix to our machinery, as those specifications aren't applied willynilly & without forethought.
So if we aren't lube engineers we'd be well advised to follow the specified lube call-outs for our machinery, lest we shoot ourselves in the foot, trying to improve, or re-engineer our lubrication needs, without ALL the facts!!!!! lol
SlickWiSlick
Feb 26, 2009 07:32 PM
ReAX
May 13, 2006 01:45 PM
Seifferlein
Dec 16, 2003 06:22 PM
team green
Garage & Workshop
15
Aug 10, 2002 10:20 AM
gdavis2265
Mar 19, 2002 11:57 AM
