Bronco II Ford Bronco II
84 engine dies when stopping
Old Sep 7, 2007 | 10:23 PM
84B_Ron_CO2's Avatar
84B_Ron_CO2
Question 84 engine dies when stopping
Hi Guys. Here's the deal. I'm not a car guy, but I'm pretty smart. Anyway, last year B2 ran fine, but the carb leaked like a rusty bucket. Swapped out the 2.8l carb with a TB from a 3.8l T-Bird with the harness, computer, sensors, and put in electric fuel pump. (thanks to all who helped with that) Runs wonderful in park and on the road, lots more power. BUT, when trying to come to stop, the auto tranny doesn't seem to downshift and the engine dies. Then it doesn't seem to want to start, like the engine is straining against the tranny. If I floor the gas, it will start but the engine races wide open. As long as I keep it floored I can take off and get back to highway speeds, and it runs fine as long as I don't slow to a crawl or stop. If I don't floor it and let it sit for an hour, or so, it will start right up with no extra gas and zips along like nothing ever happened. But if I slow to a crawl, or stop, it happens again. Anyone have any ideas on how to fix it? Is the downshift vacuum driven, because my vaccum lines are pretty bad.
Old Sep 8, 2007 | 01:47 AM
rebocardo's Avatar
rebocardo
Sounds like the TFI module might be bad. Might be a bad dist/pickup.
Though if you have bad vacuum hoses, that will do it too. Is your dist. the stock one, do you have the vacuum advance on the dist. with the octane rod?
Old Sep 8, 2007 | 11:58 AM
Lead Head's Avatar
Lead Head
Try cleaning the Idle Air Control valve, or replacing it?
Old Sep 8, 2007 | 02:58 PM
rebocardo's Avatar
rebocardo
You know what, I was thinking about this some more.
I bet your cat. converter is clogged! Trouble with the transmission shifting and hard starting combined together are a good indicator, plus, dying at idle.
You had a rich running carb, then you added an intake from a different engine.
If I were you, I would run a "test" pipe and see if that clears it up. Or just unbolt the in front of the converter and run the exhaust open.
FWIW: When I bought my current truck ($300) it was not running right. I discovered the tail pipe was squished almost competely shut. I cut it off and viola! No idle and starting problems.
Old Sep 9, 2007 | 10:45 PM
84B_Ron_CO2
Thanks for the quick replies. My back is out, so I haven't had a chance to look at your suggestions today. I'll get a can of cleaner tomorrow and clean all the linkages and sensors. If my back cooperates. The dist. is stock with the octane rod. The TFI module may have gone out on me. How do you check it?
Old Sep 14, 2007 | 02:50 PM
rebocardo's Avatar
rebocardo
You can bring it to a store for testing, thought it will most likely fail when hot. So, the best thing is a spare you can bolt on for testing.
expeditionph
May 24, 2015 07:48 PM
bowhunter4bucks
1997 - 2003 F150
Nov 27, 2014 09:48 AM
Jasonsb1980
Mar 11, 2011 01:57 PM
TigerDan
Jun 14, 2004 09:22 PM
chuckbadger
1983 - 2012 Ranger & B-Series
Oct 26, 2001 10:06 AM
