2.8 carb ISC
Old Oct 23, 2001 | 02:11 PM
chuckbadger's Avatar
chuckbadger
2.8 carb ISC
I have an 84 Bronco II (same as the Ranger) with the Motorcraft 2150 carb. I am trying to get the ISC solenoid properly adjusted to stop the hunt at idle. I have the solenoid backed off now so that it doesn't do anything, but then I have to have the idle adjusted up high to keep the engine from lugging down and dying when I put it in gear (auto transmission). Haynes and Chiltons both say nothing on the ISC, other than the idle is controlled by the computer. Any ideas?
Old Oct 25, 2001 | 02:47 AM
ludis's Avatar
ludis
2.8 carb ISC
I'm having the same sometimes-hunting-idle problem. How are you adjusting the idle speed without the ISC? The throttle stop screw (somewhat vertical screw by cyl. 6 corner of carb) isn't for adjusting idle. It is for adjusting the fully closed throttle position when the engine is shut off. It keeps the throttle plates from sticking in their bores when they are closed to keep the engine from dieseling.
Ludis
Old Oct 25, 2001 | 02:12 PM
chuckbadger
2.8 carb ISC
I am using the throttle stop screw to set the idle speed. I realize this is not what it is for, but at least the engine doesn't die when I put it in drive or reverse with the truck stopped. I am hoping that someone here can tell me how to adjust the ISC.
Old Oct 26, 2001 | 10:06 AM
dlmorrow's Avatar
dlmorrow
2.8 carb ISC
Erndale
Dec 23, 2015 07:03 AM
FRANKIE_FORD
20
Apr 2, 2015 10:34 PM
bigmacmondayf250
33
Jul 22, 2014 07:44 PM
danintexas
19
Jul 11, 2014 03:18 PM
jzlvr1
Nov 1, 2005 09:04 AM
