Gear rollover noise
Old Sep 7, 2007 | 08:59 PM
kmans777's Avatar
kmans777
Gear rollover noise
I'm getting what I have read here and other places is gear rollover noise from my 6 speed. Use to just do it if I left it in second and did a rolling stop. Now I'm getting it when I start out in first from a full stop. Not sure if this is indicative of a worsening condition or not. Noise usually lasts for two to three seconds. Depends on how fast I accelerate. Faster acceleration = shorter duration. Tranny fluid hasn't been changed for some time. I have a Luk clutch that's been in for approx 70k. These 6 speeds have auto tranny fluid in em, wonder what putting in standard gear lube would do to it? I remember reading a post from someone who did that. Anyone come across a solution for the noise? Or a fix (other than a dual mass flywheel)?
Old Sep 7, 2007 | 09:13 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Don't use gear lube...it's way too think and it shifts much better with ATF.
On that subject, use a good synthetic ATF to quiet it some, but it's always going to do it when you lug it.
The flywheel has nothing to do with it, the ZF-5 trucks with a DMF have the exact same noise.
Old Sep 7, 2007 | 09:54 PM
kmans777's Avatar
kmans777
Thanks Cookie. So would you say this is more a time and mileage thing than an actual problem getting worse?
Old Sep 9, 2007 | 09:01 PM
cookie88's Avatar
cookie88
FTE Emeritus
I didn't read anything in your description that seems off at all. Mine has made basically the same noises since day one.
Coby Young
Jun 13, 2017 06:20 AM
B-Rad88
34
Jan 15, 2017 12:55 PM
Alsride
29
Jul 25, 2016 09:27 PM
V8SHO
15
Jun 4, 2016 11:31 AM
savage250
15
Mar 26, 2012 08:27 AM
