Kickdown adjustment on carb
Old Sep 7, 2007 | 12:23 PM
opus's Avatar
opus
How do I adjust this screw properly? It has wiggled loose and is of no effect. If you stomp the throttle it wont kickdown as supposed to.
http://picasaweb.google.com/pmilne/M...12608396877922
Old Sep 7, 2007 | 12:36 PM
Freightrain's Avatar
Freightrain
I would suppose you would get it to react to the carb when you get WOT. Trial/error I would guess? Keep moving it down til it works when you want it.
I'm sure there might be an actual measurement, but not sure who would know that?
Old Sep 7, 2007 | 02:15 PM
blue68f100's Avatar
blue68f100
Hold the throttle wide open and check to see if you have any play on the kick down rod. If so use the screw to adjust it out (at WOT).
Old Sep 7, 2007 | 02:20 PM
Mil1ion's Avatar
Mil1ion
That's not how you adjust a kick down rod.
You bend it to alter the shift change.
That screw is for the solenoid stop
aka: Dash pot
Old Sep 7, 2007 | 02:30 PM
Mil1ion's Avatar
Mil1ion
On a carb with a cable instead of the arm that you have.
this is how it's adjusted.
THROTTLE KICKDOWN LINKAGE ADJUSTMENT
1. Move the carburetor throttle linkage to the wide open position.
2.Insert a 0.060 inch; thick spacer between the throttle lever and the kickdown adjusting screw.
3. Rotate the transmission kickdown lever until the lever engages the transmission internal stop. Do not use the kickdown rod to turn the transmission lever.
4.Turn the adjusting screw until it contacts the 0.060 inch; spacer.
5.Remove the spacer.
Old Sep 7, 2007 | 02:32 PM
blue68f100's Avatar
blue68f100
The above adj is what the book says. My method still works. They just want some extra play so you do not bottom out.
Dashpots only effect closed throttle. My 68 had no solenoid (does have factory air) , to old for high tech device.
They would have added another fuse, 4 is way to many.
Old Sep 7, 2007 | 03:48 PM
opus's Avatar
opus
That rod certainly has a lot of throw to it. So I WOT and then the rod shouldnt move but a little bit, just to keep it from being bottomed out?
Old Sep 7, 2007 | 04:04 PM
blue68f100's Avatar
blue68f100
Correct, should be around 1/2 - 1 turn off zero. 0.060 is almost 1/16" if you want to eye ball it.
Old Sep 8, 2007 | 04:29 PM
opus's Avatar
opus
I held it WOT and the kickdown rod could move toward the firewall another inch or so. I screwed the screw in until the play was out minus 1/16". That put the screw almost totally screwed in.
Was this correct?
Old Sep 9, 2007 | 11:17 AM
Danger_Dave's Avatar
Danger_Dave
just get it to where you can eyeball it and it looks good, then take it for a spin and see how it feels and if need be then adjust it a little more. sometimes with these old trucks thats the best method. thats what i did and my kickdown linkage works like a swiss watch
Old Sep 9, 2007 | 02:15 PM
opus's Avatar
opus
Done, feels good.
