Torque Spec For Front Spindle Nut
Old Sep 7, 2007 | 09:29 AM
mxzdoo's Avatar
mxzdoo
Hey Guy's, Just doing a little leg work for a buddy. His truck is a 2000 F250 Stroke that's in need of new wheel bearing's on the front end. Any of you guy's know the torque spec of the castle nut on the spindle? Shocking to find out how much the bearing/hub assembly is to replace on that truck $317 per side from Ford. Even more expensive from auto parts stores. My 97 has manual 4x4 shift. His is electronic shift w/ servo. Must be why the big price difference?
Old Sep 7, 2007 | 09:41 AM
rebelchevy02's Avatar
rebelchevy02
Theres no spindle nut on these. Its a sealed unit bearing. Once you take the hub off, theres a snap ring on the axle, some little spacers. Then on the back side of the knuckle theres 4 nuts you remove, and its off. Its not the traditional two bearings on a spindle setup your 97 has. Generally when you get the new bearings, they 1 do not come with a new inner o ring seal, and you will have to swap over the 4 studs that hold the bearing to the knuckle. They usually come with new lug studs installed though.
Old Sep 7, 2007 | 09:50 AM
mxzdoo's Avatar
mxzdoo
I haven't seen it yet, but according my buddy, he was saying he thought he needed a 2" deep well socket to get a nut off after removing the snap ring.
Old Sep 7, 2007 | 09:52 AM
rebelchevy02
There should be 3 plastic spacers in there. Two of them are round, and another is a hex and looks like a nut. However it just slides out.
Old Sep 7, 2007 | 10:08 AM
mxzdoo's Avatar
mxzdoo
Wink
Thanks for the info Reb. Much appreciated.
Kirbys73F100
May 23, 2013 01:06 PM
390XR7
Oct 3, 2011 09:21 PM
NickE
Apr 22, 2011 12:00 AM
1994 F250: 351, C6
Dec 18, 2007 01:11 AM
arnold
2004 - 2008 F150
Oct 21, 2007 08:10 PM
