General Diesel Discussion
Why no glow plug light?
Old Sep 6, 2007 | 11:05 AM
'86Clifford's Avatar
'86Clifford
Hi.
I'm new on this forum and new to diesel trucks.
What would cause my glow plug light not to come on?
The first thing I checked was fuses which were all good.
Next I switched the glow plug relay. No help!
Any suggestions would be most appreciated.
Thanks in advance!
Old Sep 6, 2007 | 11:59 AM
fellro86's Avatar
fellro86
More than likely your glow plugs have gone bad.
Old Sep 6, 2007 | 01:44 PM
stormyrider's Avatar
stormyrider
Common failure on these are the glow plug relay,volt meter and see if it is passing power, glow plug wiring harness where it passes through the tappet covers or under the tappet covers. Could also be defective glowplugs but those would be the least likely. Test glow plugs by removing the connector and use an ohm meter. resistance should be under 1 ohm if good. Normal failure on the plugs is to burn open.
Old Sep 6, 2007 | 01:45 PM
firemediceric's Avatar
firemediceric
Not to over simplify, but are you sure the bulb in the dash is good?
Old Sep 6, 2007 | 02:40 PM
'86Clifford
Thanks for the quick responses guys.
The plugs are new as of this last winter.
Also, I don't think it's just a bulb in the dash because the truck won't start unless I give her a small spritz of either.
Also, is that a voltage regulator on the inner fender near the Relay?
Old Sep 6, 2007 | 08:57 PM
Joshua0606's Avatar
Joshua0606
I know of two trucks that had the same problem last winter. New relays fixed them both.
kent hittle
Nov 21, 2015 06:56 AM
Texasthb
Jul 24, 2015 12:09 PM
mabc926
Aug 28, 2010 12:51 AM
ScottInTexas
Jul 10, 2009 06:57 AM
ronsonmax
Feb 29, 2008 07:41 PM
