starter ?
Old Sep 5, 2007 | 09:33 PM
gbeach's Avatar
gbeach
starter ?
alright guys, I need help so I don't buy the wrong thing, just got home luckily.
truck ran fine all day, stopped at wal mart, and came out. turn key, and all i get is one click, won't turn over. head lights are ok, tried jumping off my fatherinlaws dodge cummings, nothing. beat on starter wiggled all battery cables conn. nothing glow plug relay clicks ok. finally he pulled me and i popped the clutch to get started. got home and turned off and tried, still one click(starter). batteries or starter.
f250 7.3 l 1993 5 spd
thanks guys
Old Sep 5, 2007 | 09:44 PM
a711112a's Avatar
a711112a
clean you r battry termanels
Old Sep 5, 2007 | 09:48 PM
gbeach's Avatar
gbeach
had aready tried that
Old Sep 5, 2007 | 10:43 PM
speedrdr's Avatar
speedrdr
check the voltage regulator for corrosion. don't know where it is on your truck but mine was pretty close to the p/s battery and the terminals where the plug connects were pretty corroded. made starting an iffy process. cleaned everything up and worked better. maybe this will help.
speedrdr
Old Sep 5, 2007 | 10:44 PM
farmert's Avatar
farmert
Check the nut that holds the battery cable on the starter. I have had it loosen and would just get the click.
Old Sep 5, 2007 | 10:49 PM
speedrdr's Avatar
speedrdr
a "friend" of mine told me to check the nut holding the wheel. took me a minute to figure out that i needed to upgrade friends. LOL
speedrdr
Old Sep 6, 2007 | 07:14 AM
gbeach's Avatar
gbeach
don't have any corrosion. I am leaning towards the starter, because the click at the starter is strong, and you can hear glow plug drawing current and cycling ok, which sucks a lot of current.
Old Sep 6, 2007 | 08:50 PM
gbeach's Avatar
gbeach
well, it wasnt the starter, tried a new one, same thing. guess i'll try batteries next. any ideas
Old Sep 6, 2007 | 08:58 PM
dwaymar's Avatar
dwaymar
check bat cables real good ask a few of us who look and said they look good but after cutting them up to find corrosion up under the insulation
Old Sep 6, 2007 | 09:21 PM
gbeach's Avatar
gbeach
don't understand why truck had started fine just 5 minutes earlier.
Old Sep 7, 2007 | 11:53 AM
gbeach's Avatar
gbeach
ended up being the positive cable. had a partial open from 2nd battery to starter 200 ohms resistance, 0 when I flexed the cable, guess I got myself a brand new starter for nothing.
Old Sep 7, 2007 | 11:55 AM
speedrdr's Avatar
speedrdr
but look at the fun you had putting it on. LOL
speedrdr
Old Sep 7, 2007 | 09:28 PM
gbeach's Avatar
gbeach
cable fixed it. starts strong .
Old Oct 11, 2007 | 03:47 PM
jongirouard's Avatar
jongirouard
hi gbeach..how hard was it to change the starter?
that 3rd bolt looks like a tough spot for me.
I am looking into changing mine maybe.
got starting problems too. started a new thread on it...
thanks jon
Old Oct 16, 2007 | 06:46 AM
gbeach's Avatar
gbeach
it was very easy.
