good transportation?
Old Sep 8, 2007 | 09:46 PM
Franklin2's Avatar
Franklin2
One thing that encourages me to look for a well cared for twenty plus year old F150 or F100 is parts availability. I'd guess that due to their vast numbers out there that oem and aftermarket parts would be (relatively) plentiful and inexpensive. Is that correct?
You are correct. The calipers stick often, but they are cheap. The parking brake cables rust and get stuck too, but they are cheap also. The gas tanks rust out, but they are about $100.00. The brake boosters go bad, but they are about $100 too. If you have frame rust problems, the local dealership actually keeps some of the spring perch brackets in stock. They are about $40.00. They also keep the ignition key tumbler and the lever actuator in stock too. They sell boat loads of these.
