400m Motor mount problem
Old Sep 5, 2007 | 01:20 PM
RJR99SS's Avatar
RJR99SS
Here's the story, i pulled the 400 out of my f250 (it's the original engine) to be rebuilt. The old motor mounts were shot so i got some new ones. I put the new mounts on the block, lower the block into place, and it just doesnt look like it's fitting.
Basically, the studs on the mounts are just bottoming out in the slot holes on the frame tower, and theres about 1/4" of space between the mount and the frame tower. At first i figured maybe they'll flex in some when i tightened them, i didnt get them very tight at all and the one stud just broke off.
I figured i must of got the wrong mounts, went and got another brand of them, put them and place, and i still get the exact same thing!
From what the parts people tell me, there's no difference between the 4x4 and the 2wd version of the mounts. So i'm at a loss here, anyone know whats going on?
Old Sep 5, 2007 | 03:05 PM
RJR99SS's Avatar
RJR99SS
Nobody eh? Problem is i took this thing about 5 months ago, now i dont remember how everything goes back together.
Although...now i do seem to remember something about there being washers that shimmed in between the block and the mount, i suppose i'll just try that...
Old Sep 5, 2007 | 05:14 PM
RJR99SS's Avatar
RJR99SS
alright...i used a bunch of washers as shims, took me about 3 hours but i got the one side dead on, the other side had maybe 1/16 space in it, i tightened everything down, and just ended up breaking the stud off that side again. It'd be really nice to know if i'm even supposed to be shimming this thing, or what the problem is...anyone have any clue at all?
Old Sep 5, 2007 | 08:32 PM
danlee's Avatar
danlee
Do you have the old motor mounts to compare?
I don't know what studs you are referring to. My mounts have a large bolt and nut, but I don't have an F250.
Old Sep 5, 2007 | 11:50 PM
RJR99SS's Avatar
RJR99SS
I compared the old mounts to the new ones and they looked identical. I'm talking about the single stud that goes through the frame tower. I have to shim the three bolt holes going through the mount and into the block to get it to fit right.
Apparently i just have to keep trying...what a pain in the ***.
Old Sep 6, 2007 | 09:14 AM
mikeismadness's Avatar
mikeismadness
Hm, on my F250 i have a 400m and it looks like the frame has been cut. i was told people did those for 460s mainly but it might just be your problem
Old Sep 6, 2007 | 10:40 AM
RJR99SS's Avatar
RJR99SS
No...the frame wasnt cut, the 400 was the original engine for it, and it definitely looks like it was never pulled before.
I asked around some other boards and i've found a few other people who have that problem. I'm still not sure if it's just the quality of the "made in india" mounts i seem to keep getting, under different brand names, or if it's just like that from the factory...
Old Sep 6, 2007 | 04:01 PM
mikeismadness
who knows. I know my frame was cut its easy to tell. WE need to make stuff here in the US
Old Sep 6, 2007 | 04:03 PM
mikeismadness
also, try bolting them to the frame instead oif the engine and just make the engine fit to the mounts doesnt sound good but u can get it to work
Old Sep 6, 2007 | 04:39 PM
RJR99SS's Avatar
RJR99SS
Yeah, i tried that first, i didnt even come close to getting it into place.
Old Sep 6, 2007 | 05:39 PM
havi's Avatar
havi
I'll have the Roast Duck
4x4 and 2wd are different, ever so slightly (atleast they were on my 300-6 79 bronco). Are you certain left is on left, and right is on right? Assembly is done (by the book) by setting the mount into the frame perch, then put the washer and nut on, but leave slack. Then bolt the mounts to the block. Then tighten the nuts. If you keep going side to side little by little, you'll put even pressure on both sides which might keep from snapping a stud.
What danlee has, is the car version...which is the street rod version.
Old Sep 6, 2007 | 07:03 PM
danlee's Avatar
danlee
Yes, my mounts are the car version. My motor dropped right into place, I just had to align the mount to the perch and drive the bolt through.
A stud should be easier, but what keeps the motor from dropping onto the perch?
Old Sep 6, 2007 | 08:11 PM
havi's Avatar
havi
they sit at an angle, so the tip of the stud doesn't go straight in. If the stud is too long, it hits the outer edge of the perch hole.
Old Sep 6, 2007 | 08:36 PM
danlee's Avatar
danlee
I would put the stud in the perch and just put the nut on a few threads, then put the bolts into the block. Don't tighten anything until both mounts and all bolts are in place.
I think that is what the 'book' is saying.
Old Sep 6, 2007 | 09:07 PM
RJR99SS's Avatar
RJR99SS
Well...with these "made in india" mounts, there's about 1/2" of space total that has to be pulled in. I can get it in close, but i wont even get the nut even close to tight on one side before it just snaps off.
I ordered some other mounts that looked closer to the ones that came with it originally, so i'm hoping those will fit a lot better. Unfortunatly i wont know until next week.
