390 oil pump installation
Old Nov 24, 2002 | 11:50 PM
BB's Avatar
BB
Old Nov 25, 2002 | 06:34 PM
gadams's Avatar
gadams
Do you guys have a procedure for installing an FE oil pump? I'm trying to do it right now, and can't seem to work out how to line up the distributor driven shaft while holding up the pump with my fingers through a 2 inch gap above the oil pan!
Greg
67 F100 CCS 390 FMX
Old Nov 25, 2002 | 06:56 PM
flyboy2610's Avatar
flyboy2610
When I did mine, I removed the oil pan completely. I bolted the pump on, without the pickup tube in place. Then position the pan, and install the pickup tube. This way you should have enough room to work. If you haven't ubolted the engine mounts and jacked up the engine, you may want to consider doing that too. Gives more room. The pump drive shaft can be frustrating, but I think my method may help. You may even consider pulling the dizzy, and installing it after the pump is in place. Good luck.
Old Nov 26, 2002 | 12:52 AM
rustyrim's Avatar
rustyrim
i have used a rubber band to hold the drive in the distributor and after the pump was in i broke the band by pulling it apart.good luck
Old Nov 26, 2002 | 06:45 AM
tomw's Avatar
tomw
Pull the distribulator. That lets the drive shaft rotate freely enough to install the pump. If you're lucky, the distributor will drop back down in place with a little pressure on the hold-down while you bump the engine over with the starter... Uh, don't forget to remove the leads to the coil when bumping it over, or it may start... at least, make sure the oil is already in if you don't.
tom
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
