Recent project thought I would show the progress!
Old Sep 10, 2007 | 10:50 PM
big hoss 29's Avatar
big hoss 29
Originally Posted by gearhead351
ITS ALIVE!!!!!!!! Fired first turn! ran for 25min at 2300rpm and its got a couple bugs in it but NO leaks first try! 65lbs oil oil pressure at 2000rpm! seems a little high to me but oil pressure is a good thing. and at 205 degrees the whole way! Its got a couple noisy lifters so I need to crank down on the roller rockers adjustment screws. How long does it take before I can drive it?
That's awesome news!! Way to go.
As far as driving it goes, unless you mean drive it, I would think that after you adjust the rockers and change the oil you should be able to drive it easy right away. Full break in is around 2500 miles or so, so until then, just don't push the engine too hard. After that, stand on it son!!
One rule I've always followed is to change the oil right after you shut it off the first time, 500 miles after that, 1500 miles and then 2500 miles and then every 3000 miles. It may be overkill but clean oil never hurt anything and it's cheap insurance for that investment you just rebuilt.
Old Sep 10, 2007 | 11:24 PM
gearhead351's Avatar
gearhead351
I meant by driving it like getting on freeway on ramps. I do intend to change the oil at the end of the week after some idling and NICE driving at 45 or so. Should compression raise as I break it in? I tested it after a half hr of break in and another hr of idling. It is a little low..... NO blow by the like it used to have. What should it read at? I miss calculated it really is a 377 not a 383. One decimel is all it took to get me too happy.
Old Sep 11, 2007 | 12:33 AM
big hoss 29
My grandpa took his 79 F-150 with a new 351 from Reno to Duluth Minn. and back as a break-in after only having the new engine in for two days. He varied the speed from 55 to 75mph and he never had a problem with it. He was a braver man than I would have been that's for sure.
It only took me 3 weeks before I couldn't resist the urge to pull the cork on my 460 and see what it could do, so I think that should be a good time period to take it easy on your engine.
Old Sep 11, 2007 | 01:09 PM
gearhead351
wow, i wouldnt even think about driving 10 miles from home right now! 3 weeks isnt to bad, but I was born with a lead foot. Resisting will be very difficult buts its for the better. I should take a video so you guys can hear what she sounds like!
Old Sep 11, 2007 | 01:19 PM
bobzdar's Avatar
bobzdar
The harder you drive it, the faster the rings will fully seat. All I'd do is do a highway drive varying speed from 50-70mph every few minutes for about half an hour, then stand on it to seat the rings.
Old Sep 11, 2007 | 09:40 PM
gearhead351
yes ive learned in the past the harder u push the faster it happens. Ive went from 90lbs after the first 25 min run in the driveway. I drove 35-45 miles per hr for 50 miles and im about 120. So i know its going the right way. Last thing I wanna do is mess up my nice aluminum hyperuetectic coated side skirt pistons!
