need c6 info
Old Sep 4, 2007 | 09:58 PM
YoungMT Hick's Avatar
YoungMT Hick
need c6 info
what is the shift pattern on a c6. have a 77 f250 with a 400 and doesnt seem to be getting that last shift. runs on the road at 80 about 3K and 60 at 2.3K should it kick down when you floor in like when your going to pass or no? what should it be revving at on the highway
Old Sep 5, 2007 | 11:47 PM
85e150's Avatar
85e150
Does it shift twice?
Those revs sound right with lower gears like a truck would have and a 3 speed with a 1:1 3rd gear.
Old Sep 6, 2007 | 07:10 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
1-2 and then 2-3. That's all the shifting a C6 does.
That depends on your speed when you floor it. If you're going to fast for second gear it won't shift when you floor it.
Old Sep 6, 2007 | 01:18 PM
YoungMT Hick
hey thanks guys ya i was thinking it probably has 411 in the rear so it might just run high idk but ya sounds right. the problem with it is that it leaks bad and sometimes will kick out of gear so you have to give it some gas to kick back into gear
Old Sep 6, 2007 | 10:30 PM
85e150's Avatar
85e150
If it disengages while driving, and you do not have shifter or linkage issues, and then re-engages when you gas it, you are on the verge of transmission catsasstrophy. Eventually, you will gas it and be answered by a 'BOOM' which will coincide with the rear wheels locking up momentarily, the rear axle hopping off the ground and then a coast to a stop, either with the engine running or in silence if you kill the motor. (at least that's what I saw happen to the neighbor years ago...shoulda seen the parts that came out of that one...)
Get this taken care of. No, it's not cheap.
Good luck.
Old Sep 7, 2007 | 06:43 PM
73F100*8Mile's Avatar
73F100*8Mile
Oh I dunno about it not being cheap. I rebuilt my C6 myself for $75. Kept the converter, cleaned the inerds of the tranny, got a rebuild kit and good to go. Take your time. If you're up for the challenge.
royalchoppers
Jan 23, 2016 02:47 PM
boojumm
Dec 26, 2014 07:21 AM
sweetlou1
Mar 8, 2013 10:18 AM
IDIDieselJohn
Jun 19, 2011 10:05 PM
