lurches at 65 mph
Old Sep 4, 2007 | 10:19 AM
slapshot69's Avatar
slapshot69
lurches at 65 mph
95 F-150,4.9L, manual transmission. Runs fine in town, At about 65 mph the engine starts to lurch. I changed egr valve, egr sylonoid,plugs and plug wires. Any other ideas.
Old Sep 4, 2007 | 10:24 AM
Skandocious's Avatar
Skandocious
Have you vacuum tested it?
Old Sep 4, 2007 | 10:29 AM
slapshot69's Avatar
slapshot69
not yet. I'll give that a try. Thanks
Old Sep 4, 2007 | 10:42 AM
hotshot414c's Avatar
hotshot414c
it was the tps causing mine to do that. should have a code.
Old Sep 4, 2007 | 01:29 PM
slapshot69's Avatar
slapshot69
where is the tps located? have any idea how much it is?
Old Sep 4, 2007 | 01:44 PM
92F150Flare's Avatar
92F150Flare
Welcome to FTE
Either on the side or the bottom of your throttle body........a Haynes manual can give you a better idea and has the tests for it too. I bought one at Advance about $38......took it back after I didn't need it. Many here recommend using a Ford part rather than the parts stores for that though......probly $50 or so.
Old Sep 4, 2007 | 01:45 PM
Redtires019's Avatar
Redtires019
check the fuel filter. if the pump is getting weak or the pump is restrictive it may be running out of fuel at that point.
Old Sep 4, 2007 | 01:52 PM
slapshot69's Avatar
slapshot69
Thanks for all of the advice. I'll try them all until something helps. I may be back later if nothing suggested so far helps.
