Lawn Dethatcher?
Old Sep 4, 2007 | 07:39 AM
Bruker's Avatar
Bruker
Question Lawn Dethatcher?
Has anyone here ever used one of those non-powered lawn dethatchers that you pull around behind your mower? Do they do a good job?
Old Sep 4, 2007 | 11:39 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Like a lawn sweeper? I have one of those and it works just so-so.
Old Sep 4, 2007 | 11:42 AM
Bruker's Avatar
Bruker
No, not quite. A dethatcher has around two dozen wire tines that pull through the grass supposedly catching the thatch and flinging it up so it can be collected by a sweeper.
Old Sep 4, 2007 | 12:10 PM
Nitramjr's Avatar
Nitramjr
I have one that I bought at Lowe's for around $80. I put 4 bricks on it and it works amazingly well. Without the bricks it just bounced around a lot.
I have a 1/2 acre lot and I dethatch once a year. When I did it this past spring I made a pile about 6' tall so it definitely gets the thatch out.
You don't have any idea how badly I wanted to throw a match in the pile....
Old Sep 4, 2007 | 12:14 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Yessir!!!!!
I used mine yesterday!
I've had this de-thatcher for about 20 years.
I use two 5-gallon containers that have tight fitting lids and vent caps and fill them with water from the spigot, for extra weight.
The wheels are adjustable for the height of the 'tines'. I set mine so that I get the most effect from the 'tines'.
I haven't rented a de-thatcher since I bought this one.
After using the de-thatcher, I put the bagger on the riding lawn mower, and pick the thatch up using the mower.
(With my beat-up body, I don't rake.)
Works great!!!!!!!
Old Sep 4, 2007 | 01:33 PM
tewferford's Avatar
tewferford
I have one also, it works mint, but you do need the weight on it.
Old Sep 4, 2007 | 01:39 PM
94van's Avatar
94van
I have one also. I use 2 cinder blocks on mine to keep it from jumping all over the place.
Old Sep 4, 2007 | 04:12 PM
CobraXP's Avatar
CobraXP
Use mine every spring right before fertilizing and seeding...
Old Sep 5, 2007 | 01:20 AM
1979 Ford's Avatar
1979 Ford
I guess the first question would does it really need the tines or aeration? The type of areation would be removing the core from the ground. Also if do use a tow behind weigh it down. I would go over the lawn twice, 90 degree to each other.
In cool season turf it may (depends on condition of grass) need to be done in the spring.
Greywolf
Apr 12, 2012 12:44 AM
Greywolf
49
Oct 2, 2008 01:12 PM
ranger rules
20
Mar 22, 2007 02:28 AM
jimbeamalki
21
Mar 29, 2006 02:19 PM
19903024x4
21
Dec 26, 2005 09:57 PM
