Replace A/c Controls To Digital Ones?
Old Sep 3, 2007 | 09:49 PM
Byos's Avatar
Byos
Hey guys can i change my Dull 3 **** A/C CONTROLS with the DIGITAL Controls?? is it a stright swap?? It should right?? it's the same mounts..
Mines a 2001 Limited X V10..
Let me know guys thanks..
Old Sep 3, 2007 | 10:15 PM
Monsta's Avatar
Monsta
Sit. Stay.
You'll need the interior temp sensor and the exterior temp sensor. You may already have the latter. Not sure if it is plug-n-play but I would guess it would be.
It should be noted that at least once a week someone posts a problem with the electronic ones while I've never seen a problem posted about the manual ones. 'Cept maybe a **** falling off...
Old Sep 5, 2007 | 12:46 AM
RACERX7775's Avatar
RACERX7775
i dont think that its a swap even with the interior temp sensor. arent the dial type operated by cables?
Old Sep 5, 2007 | 01:29 AM
Monsta's Avatar
Monsta
Sit. Stay.
I don't think so but don't know for certain. Maybe I'll pull it out tomorrow and look.
I think it is electrical which drives little servos to open and close the blend door.
Old Sep 6, 2007 | 07:29 PM
rlh68050's Avatar
rlh68050
No, I don't think so. I believe that the dial HVAC system is vacuum operated. It uses engine vacuum to actuate the blend doors and the temp controls. The electronic HVAC uses all servo motors to do the same. Pull the head unit and see what is connected in the back. If it is vacuum lines + electrical connectors, it is not an easy swap. If it is all electrical connectors, then maybe.........
Old Sep 7, 2007 | 01:14 PM
K9BELLA's Avatar
K9BELLA
The dial type are operated by vacuum.
