Droping in a 300
Old Sep 3, 2007 | 05:52 PM
lemcham's Avatar
lemcham
Droping in a 300
I am taking out my old 300 and putting a new one in. I have never done an engine swap before. I have a question for anyone that can answer, what are some of the problems that I could run into? Would I need a special tool to hook it up to the belhousing?
Old Sep 3, 2007 | 06:30 PM
classicranger's Avatar
classicranger
Should go right in , stab the trans before trying to let it down on the engine perches.If you have an auto trans remember to remove the torque converter nuts first, and when installing have someone help you guide the torque converter studs into the flexplate.
If you have a manual trans don't forget the pilot bushing that goes into the end of the crankshaft. no speacial tool needed for the bellhousing, just take your time and mate the 2 together, there should be no forcing it, if mated correctly it will be fairly smooth.
good luck
70T351W
700
Apr 13, 2022 09:48 AM
75Three90
Apr 26, 2013 08:44 PM
bcallahan
Feb 16, 2009 08:47 PM
turdbird
Computer Chips & Tuners
Aug 24, 2005 02:43 PM
4x4E350
Sep 14, 2001 06:54 PM
