I believe I saw the silver can on the under dash fuse box on my 2002. I think yours will be in the same place. The flasher can doesn't look like the rest of the fuses, it's a silver aluminum can about 3/4" round.
hum, well this is all I could find in your manual for relays.
211 — Backup lamps relay (Diesel engine only)
212 — Not used
301 — Front blower motor relay
302 — Powertrain Control Module (PCM) relay
303 — Fuel heater relay (Diesel engine only)
304 — Heated backlight relay
305 — Trailer tow battery charge relay
306 — Delayed accessory relay
307 — Starter relay
So I would look more towards the firewall than the fuse box.
