Sponsored by: Real Truck
Anyone have a thread on adjusting tailgates??
Old Sep 3, 2007 | 04:09 PM
makomaker's Avatar
makomaker
My tailgate is not latching on one side and the handle is not pulling out properly......
Anyone have a thread laying aroung touching on this subject?
Old Sep 3, 2007 | 05:40 PM
boxcar1974's Avatar
boxcar1974
I have not seean any recently.
Did you take off the access panel in the tailgate to see if anything needs lube or needs adjusting?
Old Sep 3, 2007 | 07:45 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
https://www.ford-trucks.com/forums/6...bed-rails.html
Look at my post. I had the same problem. No adjustments to be made. More than likely your bed rails have bowed outwards.
Old Sep 3, 2007 | 07:48 PM
F350-6's Avatar
F350-6
I haven't seen a thread but have adjusted mine before. Pull off the access plate on the inside of the tailgate (it's as long as the tailgate). You will see the inside of the latch there is a rod on each side that goes to the ends of the tailgate. The rods have a nut on them that can be loosened/tightened to adjust how much pull the handle applies. Play with it opening and closing the tailgate until it feels right, then put the plate back on.
Note: If you have a spray in bedliner you will have to cut the liner around the panel to get it off.
Old Sep 3, 2007 | 08:11 PM
makomaker's Avatar
makomaker
Thanks guys, I think I found my problem. Looks like the previous owner did something to crush the tailgate inward, like something sliding around in the bed and took a long ride into the inside portion of the gate. It looks kind of hopeless except to replace it.
