Power Mirror Removal?
Old Sep 3, 2007 | 02:23 PM
boing's Avatar
boing
I have a 1994 F350 and my passenger side mirror housing has been broken for a while but still in tact. Yesterday I was driving on some very rough roads and it finally broke off.
There are 2 torx screws on the outside what else is required to remove this?
Do I need to remove the door panel?
Thanks
boing
Old Sep 3, 2007 | 03:25 PM
quicklook2's Avatar
quicklook2
take off door panel and you will see the nut you need to remove.
Old Sep 3, 2007 | 03:27 PM
Skandocious's Avatar
Skandocious
Yeah I believe there's a bolt on the inside of the door panel that secures the mirror to the door. You'll need to remove the door panel to get to it obviously.
Old Sep 3, 2007 | 04:30 PM
quicklook2's Avatar
quicklook2
after you remove the nut than take off the two outside allen bolts and pull the mirror and the attached rod out.
Old Sep 3, 2007 | 04:46 PM
boing's Avatar
boing
Cool thanks guys.
I got it off now where is the best place to get a new one?
Old Sep 3, 2007 | 05:00 PM
Skandocious
Used - junkyard
New (repro) - http://www.lmctruck.com/icatalog/fd/0079.asp
Old Sep 3, 2007 | 05:15 PM
quicklook2's Avatar
quicklook2
go to the sponsor column on the left and go to national parts depot or bronco junkyard or any other of the fine sponsors listed.
Old Sep 4, 2007 | 06:01 AM
alz's Avatar
alz
I just replaced mine with one from BroncoGraveyard. Nice looking mirror and works good. I tried the jy first, and got one for $25. It was real stiff and didn't want to move. Sprayed with PB blaster and let soak. Next day, I went out and the plastic base and around mirror was cracked and just fell apart. That PB blaster really did the trick on plastic. It's all good now with the new aftermarket one.
