1952 starter button wires
Old Sep 3, 2007 | 01:52 PM
John Morton's Avatar
John Morton
a 1952 starter button has two wires, one runs to small lug on selenoid, I have one wireing diagram that says the other goes to ground (where ?) another says it goes to a circuit breaker. There is a small rectangle metal device under the dash (1'' x 1/2" +-) that has wires running to it, it has a spring loaded push button on one end. Is this a circuit breaker ? The two push button starter wires are red with green dashes and red with blue dashes. Niether of these colors go back to the metal device I described earlier. Any one a wireing expert on this model? Thanks ! John
Old Sep 3, 2007 | 04:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Check this thread. The Advanced Search is your friend, this very topic has come up 3 times in the last two weeks. You should also buy a factory manual if you're going to fix the truck yourself, they're only $30 and worth every penny.
https://www.ford-trucks.com/forums/6...hlight=starter
Also, MacVP has a '51 wiring diagram, which is similar but not quite the same as a '52
http://www.vanpeltsales.com/FH_web/flathead_home.htm
Yes, those are circuit breakers under the dash.
1930 Dodge
33
Dec 30, 2012 03:57 PM
travelingman55
17
Nov 22, 2012 07:41 AM
siloketh
50
Apr 1, 2012 09:52 PM
1951flatheaddave
19
Dec 1, 2011 10:53 AM
ventura23
New Member Introductions
Jun 17, 2006 06:39 PM
