Aerostar Ford Aerostar
Replace upper ball point
Old Sep 3, 2007 | 01:48 PM
huang4752's Avatar
huang4752
Smile Replace upper ball point
I'm a original owner of a 93 Aerostar. It is 2wd, with 69000 mile. It runs great. But our state inspection said that I need a pasenger side front upper ball joint. I tried to replace it myself. After I chisel out the rivet head, I still can't remove the rest of them. Is any body have succesful experince with this?
Thanks,
David
Old Sep 3, 2007 | 02:40 PM
96_4wdr's Avatar
96_4wdr
center punch a start point hole and drill out with a high quality titanium drill bit, no cheapy import here....the rivets are tough hardened steel
may also be able to drive out if enough of the head is cut off with a high quality flat tip round punch and 3 lb hammer
or use a cutting torch to blow out carefully, professional only
there are also rivet pushers if you can find one, similar to C clamp, spread claw foot to go around head with C frame and screw to force rivet out
Old Sep 3, 2007 | 02:58 PM
copper_90680's Avatar
copper_90680
I had to drill through the rivets first before punching out the heads. Then the balljoints just fall off.
briangelc
Jan 4, 2020 08:37 AM
bchez
2004 - 2008 F150
May 7, 2014 02:07 AM
werknman
1983 - 2012 Ranger & B-Series
May 9, 2005 08:25 AM
ACE81
Aug 3, 2003 04:22 PM
David Campione
Aug 18, 2002 09:13 PM
