P0455 code-evap cannister leak large
Old Sep 2, 2007 | 08:11 PM
vicv's Avatar
vicv
I have a 97 Expy with this code. My question is where is the cannister? I have 2 plastic boxes with a valve attached above the spare tire. The valve is rusty. There is a fitting connecting the 2 boxes and hoses running towards the front of the truck. Is this the cannister assy? The tray they sit on has rusted out and they flop around, I'm sure. How tight should the fittings be? They are rubber and look like "push-in" type. Thanks in advance.
Old Sep 2, 2007 | 08:34 PM
73f100shortbed's Avatar
73f100shortbed
Did this code come up right after getting gas? If so check your gas cap for being loose. Also if you leave running ehile filling up this code can be set. Otherwise check for broken hoses.
Old Sep 5, 2007 | 07:51 PM
vicv's Avatar
vicv
Found the problem. Gas station guy jammed the nozzle in hard or ripped it out hard and chipped the fill neck. Cap could not seal. Luckily the chip was still inside the fill door so I could glue it back on. Thanks shortbed for the reply.
Old Sep 5, 2007 | 07:55 PM
bcjim's Avatar
bcjim
Another reason why NJ's bizarre Full serve law should be scrapped.
Old Sep 5, 2007 | 08:05 PM
vicv's Avatar
vicv
Yeah, if I hadn't been standing there at that moment I wouldn't have noticed the problem and would have spent the better part of the weekend under the truck. We'll see how long the glue holds....
Old Sep 5, 2007 | 08:10 PM
73f100shortbed
Glad it was an easy fix for you. Glue should hold without a problem.
makuloco2000
Escape & Escape Hybrid
Aug 25, 2014 12:23 PM
steeltaber
Apr 10, 2011 08:33 PM
tseekins
General Automotive Discussion
Jan 30, 2010 02:02 PM
slrassoc
1983 - 2012 Ranger & B-Series
Feb 19, 2008 12:29 PM
SteveGiu
May 22, 2006 08:50 PM
