I would say 305-315 at the rear wheels, if and only if your fuel system is healthy. About what I had on my dyno run except the wastegate item. Don't know what that item is worth.
Proper injectors can/will get you more closer to 400HP. But if you got PMRs, 400HP might be scary.(I see you have an 02 which is a dif. sign u have PMR). With your mods i see a 290-320hp possible.
so why would jody sell me a 140hp tune if i would need injectors etc.to make it 140hp.i thought i would add another 140 to my engine with just his tune.
i'm looking at getting a chip on mine but don't really want to open it up or spend the money for the injectors what's gonna be my best chip i'd heard a lot about wildman just don't wanna have a fully modded out truck for his chip to work
His tune can make the power, your engine can't. You don't need injectors to get the full 140 hp from the tune. The stock HPOP can't supply enough oil to the injectors, so you lose on the top end. It's just like any other chip setting, you need the supporting mods or you won't get the full benefit. You can run the 140 tune with a single stock HPOP and it won't hurt anything.
I understand now,i dident know that you needed other mod to make 140hp.Is a better hpop realy worth the price?How much hp can the stosk hpop handle?
