Offroad & 4x4
Tandum rear 60s
Old Sep 4, 2007 | 03:16 PM
  #31
miker67's Avatar
miker67
Let me rephrase my self, I wish it was easier to make it legal. I know that evil chevys had or still have it, it is just difficult to make DIY systems that are legal.
Old Sep 4, 2007 | 04:30 PM
  #32
STGFordCrazy04's Avatar
STGFordCrazy04
Like I said in post 17 from what Ive read many people who build tamdem rear axle vehicles have a front axle that makes somewhat of a turn. Probably only 10-15* from what I saw but it has to help in turning radius. Like the Macks that have 1" of "slop" in the spring mount there has to be something to absorb some of the lateral stress. I dont think it would be possible to have both rear axles positive traction. I think they would fight each other too much around the street.
Old Sep 4, 2007 | 06:01 PM
  #33
likethefords's Avatar
likethefords
I think that you could take a divorced Dana 24 t-case (used in the Highboys)and flip it backwards and straight up and you would have two outputs facing the rear, one high and one low. Then use an intermediate shaft with a hanger bearing and another short shaft at an angle to reach the rear diff, which would have to be rotated up a bit to relieve the sharp driveline angle. then on the low output of the dana 24 just run a shaft right to the front (1st) diff. The one thing I'm not too sure about, is if the transfer case would be able to oil itself being straight up and down, or not. I was going to try this, but I don't want to butcher my good 78, so I will have to find another truck. Let me know what you think.
Old Sep 4, 2007 | 08:26 PM
  #34
crazyredneckanyhow's Avatar
crazyredneckanyhow
Wow this thread has went on alot longer and better than i imagined. The only problem with turning a transfer around is that i do believe it would spin backwards if im not mistakin. If i am someone let me know.
Old Sep 4, 2007 | 09:07 PM
  #35
chrono4's Avatar
chrono4
No, it wouldnt spin backwards. It would spin the same direction as the input spins
Old Sep 4, 2007 | 09:25 PM
  #36
late70sfordnut's Avatar
late70sfordnut
but it would be working on the back side of the gears and that wouldnt be good
Old Sep 5, 2007 | 10:37 AM
  #37
chrono4's Avatar
chrono4
so backing up isnt good on a transfer case?.......................
Old Sep 5, 2007 | 03:33 PM
  #38
likethefords
I don't think that the gears turning in reverse would hurt anything. I believe they are helical cut, so it would be the same either way.
Old Sep 5, 2007 | 04:36 PM
  #39
STGFordCrazy04
Somebody get off your **** and build one. I nominate Crazyredneck since he started this whole mess.
For the sake of argument I dont think transfercases, regardless of make model chain or gear, were meant to be run 100,000 miles while under the strain of 2 rear axles and the weight/payload trucks so equiped would haul/tow. It might work fine for a while but eventually you will have problems and Id suspect chain stretch would be the first. Besides that Im thinking it would be noisy at highway speed. The unit in post 24 was probably designed specifically for this application and would probably last the longest under the harshest conditions. The only reason I can see why anyone wouldnt use the splitter in post 24 is cost but on the other hand I dont see anyone building a tandem axle truck right now so that really doenst matter now does it? (Im not trying to be a smarta$$) I still fall back on Rockwells being the easiest cheapest and best way to do this since they were designed to be run like this and most likely a front and 2 rears can be bought cheaper than the splitter in post 24.
Stepping down off my soap box
Old Sep 5, 2007 | 07:05 PM
  #40
likethefords
I think that you are correct about the t-case wearing out over the long haul. But I was thinking that this was for off-road use only and for play. I don't think any tandem rear setup would be good for the street on a regular pickup. the tire wear would be insane, not to mention horrible gas mileage. If I ever do build one, it will be for bashing in the fields and brush.
reddogracing
Nov 24, 2015 03:04 PM
my 66
Feb 5, 2014 05:45 PM
carcrafter22
32
Oct 21, 2013 06:49 PM
GlamisSand1
Oct 21, 2010 07:42 AM
Alter Ego
26
Mar 22, 2009 10:42 AM
