Offroad & 4x4
lockers and 35's
Old Sep 2, 2007 | 12:20 AM
keyul's Avatar
keyul
lockers and 35's
hello, i just bought another 79 f150 today that i am going to be using as a parts truck. It has a dana 44hp in the front and a 9" in the rear. i was wondering how well these axles can handle 35's with lockers?
Old Sep 2, 2007 | 12:28 AM
FordPickMeUp's Avatar
FordPickMeUp
those axles can hadle 35's with no problems.my buddy runs 36's on his with no problems
Old Sep 2, 2007 | 12:40 AM
keyul's Avatar
keyul
good to know! whats about the biggest tire they can handle with a locker, something along the lines of a 36 or 37?
Old Sep 2, 2007 | 01:24 AM
godblessmud's Avatar
godblessmud
those will handle 38's easy
Old Sep 2, 2007 | 07:46 AM
teds74ford's Avatar
teds74ford
Gotta watch the front axleshafts with bigger tires. A buddy of mine used to have a bronco that the u-joint holes were hogged out. He had 37s on it.
Old Sep 2, 2007 | 09:21 AM
keyul's Avatar
keyul
thanks your help guys, i should be starting this project in another month or two.
Old Sep 3, 2007 | 11:56 AM
94F150-408's Avatar
94F150-408
LIke Ted said, you ay have some issues with the front 44, how much HP are you running?
Old Sep 3, 2007 | 05:17 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
with a front locker stay at 35s unless you will be doing straight line mudbogging or something thats easy on front parts
Old Sep 3, 2007 | 10:20 PM
keyul's Avatar
keyul
ive got a 300 six to use on the truck that will be getting a rebuild & cam and maybe a cylinder head from clifford. im looking to use the truck for evey type of wheeling with the exception of rock crawling. i just want to build a nice all-around rig.
Old Sep 3, 2007 | 10:54 PM
godblessmud
might wanna go ahead and go with both dana 60's front and rear just to play it safe. thats what ima do, if your like me and would rather overengineer than underengineer
Old Sep 3, 2007 | 11:20 PM
keyul's Avatar
keyul
dana 60's are sounding like the better choice now the more i think about it, the 44hp and the 9" would be nice to keep for a smaller project someday.
Old Sep 4, 2007 | 12:15 AM
godblessmud
keep in mind that you will need 8 lug wheels for Dana 60's as apposed to 5 lug for the 44/9''.
Old Sep 4, 2007 | 03:27 AM
75F350's Avatar
75F350
You can still run 5, or even six lug wheels on any D60 axle. Rock guys do it all the time.
Old Sep 4, 2007 | 08:44 AM
teds74ford's Avatar
teds74ford
Or you could run it with the axles in it, and then look for 60s if (when) it breaks. It all depends on your driving style, really. If you take it easy, stuff can hold up a long time.
Old Sep 4, 2007 | 10:29 AM
75F350's Avatar
75F350
If you do upgrde axles, you may consider something bigger than a 60 out back. I have a shaved 40 spline 60 in one of my trucks, and it has survived so far, but for the money invested could have just bought a bigger axle.
Visteon/Sterling, GM corp 14 bolt, or D70 would still be very cheap and much stronger right out of the box.
