Sponsored by: Auxito
Please help
Old Sep 1, 2007 | 10:55 PM
drakul20us's Avatar
drakul20us
Please help
I have installed a K&N cold air intake and Powerdyne throttle body spacer in my truck and ever since then I am getting a DTC of air/fuel mixture is too lean in both banks. Also my truck does no want to accelerate as fast as it used to, having a hard time getting to 3+RPM, and MPG went down the toilet to about 9. Now, when the truck is idling, my RPM go wildly up and down, and the truck is starting to take off by itself with my foot on the brake. I have replaced the MAF sensor and the IAC valve, didn't change a thing. I have narrowed the problem down to the electrical signal being sent to my MAF sensor. I have probed the wiring harness of a MAF sensor and it is at 14volts, in the manual it is specified that the voltage should be 2.0v at open throttle. My question is what would cause such a huge differential and how would I go about fixing it.
2000 F-150
4.6L v8
142,000
Old Sep 1, 2007 | 11:47 PM
khadma's Avatar
khadma
Carpenter Local 745
It has been stated here on FTE, some F150s do not like mods to the spacer and the K&N system robs MPG - the computer senses that there is more air and adds fuel to the mix.
I was going to use K&N products and changed my mind when I heard about conditions like the one that you have.
Did you ever consider replacing the mods back to stock?
K&N filters may place oil on the sensors, but you changed your already, and it maybe dirty again.
AEM has dry filters, maybe better for F150s.
Old Sep 2, 2007 | 12:18 AM
LxMan1's Avatar
LxMan1
No vacuum leaks anywhere?
Old Sep 2, 2007 | 10:00 AM
drakul20us's Avatar
drakul20us
I don't think there are any leaks anywhere, I haven't heard any, but I'm going to try some soap solution tommmorow to see if I can find anything. I'm probably going to take off the spacer see if that does anything for me. thanx guys.
Old Sep 2, 2007 | 10:15 AM
screwy's Avatar
screwy
Here's your first thread.
https://www.ford-trucks.com/forums/6...l-problem.html
Old Sep 2, 2007 | 10:48 AM
screwy's Avatar
screwy
I suspect your measuring the wrong wire. There is a power supply wire that should run between 12v and 14v. I'd check for air getting in around your spacer. The 2v would be the signal return to the computer while the engine was running around 1800 rpm.
Old Sep 2, 2007 | 02:32 PM
Club Wagon's Avatar
Club Wagon
Vacuum leaks might not be so easy to find, especially using soapy water.
Save the "soap solution" for for hard to find pressure leaks in tires. The latest trick to search for vacuum leaks is to use the unlit flow of raw gas from a propane plumber's torch to probe the areas where you suspect vacuum leaks with motor idling. Any gas sucked in will increase revs.
Old Sep 3, 2007 | 08:43 PM
drakul20us's Avatar
drakul20us
Wow, that's an excellent idea, thanx. There actually was a leak around my spacer, thank you screwy, I just took the whole damn thing off, I'll be better off without it. I did use the soap solution and when I opened up my throttle body I noticed some dirty water inside so it defintly was leaking. I didn't get a chance to run the truck yet but I hope that will be the end of all my problems, thank you all.
Old Sep 3, 2007 | 10:22 PM
LxMan1's Avatar
LxMan1
At least you have a nice paperweight
Old Sep 3, 2007 | 11:37 PM
screwy's Avatar
screwy
Glad you found your problem.
