drivers side suspension knock
Old Sep 1, 2007 | 09:10 PM
FrdKng94's Avatar
FrdKng94
Cool drivers side suspension knock
My 94 2wd F-150 has recently developed a disturbing 'knock' in the drivers side front end. It makes no noise at idle but once I hit about 25mph it starts knocking and increases in frequency and severity as speed increases. Once brakes are applied the slightest bit or the wheel is turned at all the knock stops. I've driven it for the past week on a very unevenly worn tire. Is it an alignment problem? Or perhaps a power steering or suspension issue? Any advice at all would be appreciated... I'm worried this is going to cause a very serious problem.
Old Sep 1, 2007 | 09:15 PM
88F-150pimp's Avatar
88F-150pimp
I would check the wheel bearings, and all the joints in the steering/suspension for binding or wear, specifically, the ball joints and tie rod/ drag link ends. The caster /camber is not adjustable as far as alignment, just toe in, so I wouldn't think this would be an issue.
Old Sep 1, 2007 | 11:47 PM
FrdKng94's Avatar
FrdKng94
alright.. ill try that. thanx pimp.
Old Sep 1, 2007 | 11:51 PM
khadma's Avatar
khadma
Carpenter Local 745
Wheel bearings or the radius arm bushing, the 13 year old rubber bushing maybe shot.
Old Sep 2, 2007 | 12:16 AM
grizz3000's Avatar
grizz3000
Wheel bearings is my guess. Of course, do both sides. The other side isn't far behind for sure.
Old Sep 2, 2007 | 03:21 AM
Decipha's Avatar
Decipha
yep sounds like a bearing to me as well
Old Sep 2, 2007 | 06:26 AM
alz's Avatar
alz
Check to make sure the calipers are tight. If the pins are worn real bad they will be sloppy and make a similar noise until you hit the brakes.
Old Sep 2, 2007 | 01:22 PM
KraigS's Avatar
KraigS
I had a very similar thing happen to my 96 F150 4x4. I sounded like a loose shock or mount. It was the just cone over the manual hub.
Old Sep 2, 2007 | 07:27 PM
Peter94's Avatar
Peter94
Look for loose front end parts. Jack the truck up, and move the wheel side to side. It should be a smooth motion. There should be no clunking around. Next push in on the top of the tire, there should be no movement here. Also pull up on the bottom of the tire (make sure to use jack stands). There should be no free play here as well.
Any movement is an indication of a worn out part, and the unevenly worn tire is a bigger indiaction of a worn out part.
On these trucks the only factory adjustable angle is the toe. However there are aftermarket solutions for adjusting camber/caster if you should need to do that.
More than likely if your alignment is off it is a result of a worn out part such as a wheel bearing or a ball joint. Most of the time with these trucks when you replace such parts (excluding tie rods) the vehicle will fall back into alignment specs.
most places will offer free alignment checks with a tire purchase, and being your tire is pretty choppy you might need some new ones anyway! Good luck let us know
Old Sep 2, 2007 | 09:56 PM
FrdKng94's Avatar
FrdKng94
thanks all. im gonna take a look at my bearings and ball joints tomorrow. ill fill you in on how it turns out. thanks again.
Old Sep 6, 2007 | 09:52 PM
FrdKng94's Avatar
FrdKng94
got the ball joints replaced and it fixed the issue. she sounds like a champ again. thanx so much all.
Old Sep 6, 2007 | 11:04 PM
Peter94's Avatar
Peter94
awesome. Glad to her you got it fixed. They must have been pretty loose in order to hear noises.
Old Sep 7, 2007 | 03:15 PM
FrdKng94's Avatar
FrdKng94
Yea, they were pretty much toast.
