Sponsored by: Real Truck
speedo quit
Old Sep 1, 2007 | 08:30 PM
saltnut's Avatar
saltnut
Question speedo quit
I drive an 01 F250 platnium edition and my speedometer quit today. It worked just fine yesterday and I parked it , then today went to town and nothing. any ideas would be very helpful
Old Sep 1, 2007 | 10:28 PM
pf350's Avatar
pf350
check your battery. When your battery starts to die you lose electrical at different times amd rates. Other than that your speedo sensor or dash fuses are a good place to start
Old Sep 2, 2007 | 09:03 AM
saltnut's Avatar
saltnut
thank's I didn't think of the battery I did have both of them disconnected fri. i'll try that
Old Sep 2, 2007 | 12:52 PM
yamaguy's Avatar
yamaguy
Yea and after that the first part I would replace is the VSS on the rear axle. It costs about $15. Is your ABS light on? because they both use the VSS. Not saying it couldn't still be bad though.
Old Sep 3, 2007 | 01:52 PM
saltnut's Avatar
saltnut
tried the batteries that wasn't the problem. the ABS light is not on though but 15$ is cheap enough place to start thanks
Old Sep 3, 2007 | 02:38 PM
V10'nr's Avatar
V10'nr
Abs light
The abs light might note light up till you start to drive. Mine did the same thing as yours did. I finaly replaced the speed sensor in the rear pumpkin and that cured the problem. easy 15 minute fix.
hush210
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
30
Oct 22, 2018 01:55 PM
eman92082
18
Sep 13, 2007 09:36 PM
xnman
Aug 17, 2007 10:46 PM
hobbysrus
New Member Introductions
May 7, 2006 05:06 PM
flyMike
Jun 21, 2005 07:18 AM
