Sponsored by: Real Truck
Lifted?
Old Sep 1, 2007 | 06:09 PM
FORDSDOWNER's Avatar
FORDSDOWNER
Lifted?
Q: What is the largest tire that I can fit on my stock rims without a lift?
??? A: 295's are a safe bet. But some trucks with the plow package can fit 305's with minimal rubbing. Make sure the tire manufacturer says that it is okay for THEIR tire to go on the 7" rim that the Super Duty wears.
So I found this information in the tech folder. I am running LT325/65R18 Nitto Grapplers. Looking at the pic below, could you say that I am running in a lifted vehical? Sales doc doesnt specify and I am unable to contact the OO. I initially
though that the 18s are what gives it that look. The 18s appear to be factory too.
Old Sep 1, 2007 | 07:07 PM
ReAX's Avatar
ReAX
I would say so, your running a little more than 35" tire and still have plenty of room above them. I can't really compare it, since I am not that familiar with the 05+.
Old Sep 1, 2007 | 07:26 PM
SUPERDUTY_untouchabl's Avatar
Lifted or not thats a good looking truck.
Old Sep 1, 2007 | 08:41 PM
FORDSDOWNER
SUPERDUTY_untouchabl, Thanks for the comment. Makes me feel good like that
ReAX, thanks for the reply on the lift. Is there any particular way I can tell by looking uder the truck?
Old Sep 1, 2007 | 08:49 PM
CounterMaker's Avatar
CounterMaker
measure from the ground to any point and tell me and ill measure mine at the same point and we will se if yours is lifted
Old Sep 4, 2007 | 10:58 AM
Beerstalker's Avatar
Beerstalker
Your rear end doesn't appear to be lifted at all. You may have either a leveling kit or heavy service front springs on it though, as the nose seems a bit higher than stock which is unusual with an aftermarket front bumper (they usually make the front sit lower than stock). Look at the front springs and see if there is a donut shpard piece up above it, or post a picture of the springs themselves and the trailing arms and we can tell you if they are stock or not.
Old Sep 4, 2007 | 12:27 PM
DCSpecial's Avatar
DCSpecial
Those 18s are stock.
Looks like a stock height F-250 to me.
At the most a leveling kit. If you look at the front coils there may be a spacer on the top or the bottom. Are they factory shocks?? (all black, all metal)
Old Sep 4, 2007 | 05:02 PM
FORDSDOWNER
OK, Here is the pic.
Measured the distance from the top of the bed rail down. 57" or 4' 9".
The funny thing is, I driven past Dodges that have an obviouse lift, and I am sitting just as high. lol
Old Sep 4, 2007 | 05:19 PM
CounterMaker
my truck is at 54" with 31.4 " ...stock height...FOR NOW!!!!
Old Sep 4, 2007 | 07:12 PM
Bulldog68's Avatar
Bulldog68
Looks like you have a Tuff Country Leveling Kit up front. That would explain being able to run 35's.
Nice truck by the way.
Old Sep 4, 2007 | 07:22 PM
DCSpecial's Avatar
DCSpecial
Yep, you have a leveling kit spacer
Old Sep 4, 2007 | 08:01 PM
FORDSDOWNER
Thanks for the comment, Bulldog68 . You too!
Thanks alot guys for helping me determine this.
Old Sep 4, 2007 | 11:46 PM
DanielN's Avatar
DanielN
Thats a good looking truck, and for future reference when you guys try to measure lift it would make more sense to measure from the center of the hub to the bottom of the fender, its a helluva lot more accurate because not every 35" tire is the same size. Atleast thats how I do it on my Jeeps.
