Foil Delete Glue remover
Old Sep 1, 2007 | 01:29 AM
HighOctane's Avatar
HighOctane
PMS: an obsession
OK, Just did the foil delete mod tonight. Painted both the intercooler pipes too! Anyways, I read on here the multiple ways of removing the stubborn glue on these pipes from Carb Cleaner to WD-40. What I found to work the best was a spray on gasket remover made by Permatex. $6 for a can. This stuff just melted that glue instantly, and I just used a wire brush to remove it. Took about 20 mins/4-5 songs on the radio! Not sure if this has been mentioned before, but I first tried the WD-40, and it was not nearly as easy. Hope this helps someone yet to do this mod.
Old Sep 1, 2007 | 07:58 AM
Izzy351's Avatar
Izzy351
Good to know. I used Sol-U-Strip adhesive remover which also melted it away in about the same amount of time. So how do you like the whistle now??
Old Sep 1, 2007 | 08:07 AM
Ed F250's Avatar
Ed F250
I ended up using a razor blade lol, took a while but i got it all off
Old Sep 1, 2007 | 09:00 AM
yamaguy's Avatar
yamaguy
It is on my list of mods when I meght ever get time. Thanks.
Old Sep 1, 2007 | 09:12 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I might just have to do this one this weekend. Thanks for the tip.
Old Sep 1, 2007 | 03:32 PM
blksiryder's Avatar
blksiryder
i just used old gas for the lawnmower.
Old Sep 1, 2007 | 03:51 PM
gdn's Avatar
gdn
I have used that stuff on everything from built up oil deposits to carbon on pistons & exhaust ports of 2-strokes to gaskets that it was made for and have had great results. It reminds me of some stuff call "aircraft remover" that was a paint remover for metals that you did not want to sand blast. Kind of sticky so it stays working on the stuff your trying to remove.
Old Sep 1, 2007 | 06:44 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
Absolutely! Say goodbuy to the clean wire brush! Worth it though.
