I jut put an old Holley Streed Dominator intake and a 625cfm road demon on my 79 F-250 with a 400, the cam is a Crane Engergizer with .524lift and 272 duration. Now my bellows black/blue smoke and i can't seem to get the float level set on the secondaries, I just keep screwing them down and still can't even get it to register in the window. I have had many holleys and they seem to be pretty much the same as the demon. Could the float really be about ten complete turns high? I didn't even thing they had that much adjustment in them. I can get it to idle fairly well at about 850 RPMs other than the smoke. Any help would be much appreciated.
-Johnboy
Oh yeah I took it around the block and it runs great (smoke seems to lessen as RPMS increase) and it didn't smoke at all with the two barrell i didn't pull the distributor but i did take the cap off.
Reason: more info
Sounds like a piece of debris in the rear needle and seat. Pull it out, clean it then reinstall and set yout floats. They should be just below the window.
Thanks I tried that this evening and even tried an old Holley I had with the same result I am starting to suspect intake gasket leak on sucking a little oil and causing a low vaccume condition and mabey opening the power vavle causing the rich condition. I have ordred new gaskets and its looking like wednesday before i can mess with it, I also think i will be buying a Weiand #8010 intake, I knew that single plane street dominator wouldn't have the best low end but was worse than i excpected.
-johnboy
What is your fuel pressure? I had to put a FP regulator in front of my holley to prevent the pump from blowing the needle and seat open and overfilling the bowls. I had to lower the pressure to 6 1/2 psi but it works much better.
Well I got the truck running good now, intake was sucking oil at cyls 2,3,5,and6. I put a fuel pressure gauge in the port on the dual inlet line and it reads about 6psi untill it warms up then it reads just above zero. What might cause this? Is the pump bad, or is it most likely a bad line behind the pump sucking air? I had custom exhast put on that goes no where near the fuel lines or gas tank so i don't think its boiling gas in the line. Will this cause a lean condition and ruin my motor?
I still need to check to one back on the tank the rest I replaced due to being rotten and I need to figure out what to do with the others, I think there are three returns one big one that went to the float bowl on the motor craft 2150 and two little one ones, what do you guys do with them can I just remove the carbon canister and plug them I all I am assuming one of them I need to keep for a tank vent right?
-Johnboy
