I've got this chirping noise coming from my engine. I have a 2003 with the 3.0. It only happens when the engine is at temperature and at higher RPM's. I know it's not the belt because the belt looks to be in good condition, and this chirping doesn't sound like the chrip you hear when a belt is going, it is definatly a bearing. Either the belt tensioner or the idler pulley.
I was able to get enough pressure on the tensioner (clockwise direction) to get it to losen off a little bit but I can't get it loose enough to get the belt off so I can pull off the idler and replace. So my question to you guys is how the heck do I get enough force on the tensioner to get it to slide the belt off the pulley?
Is the idler a complete unit where I would have to remove the power steering pump/AC compressor to get the thing off or can I just get the bearing? I really don't want to have to take this thing into the dealer and have then flush the AC so that they can get the compressor off.
You need to get more leverage! It will move enough to get the belt off with the right persuasion. My girls at work or I would check mine, You don't have a spot to put a ratchet in it(Square hole either 3/8 or 1/2") I never paid attention to mine. If you don't you'll just have to use a steel bar or rebar. Something you might want to try is get a long screwdriver and put it up to the pulley and listen to it. Just to make sure it isn't a glaze forming on the pulleys that can make it do a little chirp Put a bit of water all over the belt and pulleys and start it up. We had a Mack dump truck that would do it constantly real loud (not a squeal a repetitive chirp chirp chirp) It was annoying as anything you could imagine. You'll need to staple some steel wool to a contractor stake and start it up and let the pulleys do a few rotations on the steel wool just enough to get that glaze off. Be real CAREFUL and hold onto it tightly!!!!!!!!!!!!!
Don't know who's tensioner you have on your 3.0L, but my 4.0L has a 3/8" square drive hole in it's casting, that'll allow me to use a breaker bar to easily move the tensioner enough to slip the back side of the belt off the walless Idler pulley.
My 94 Taurus 3.8L @ 65K miles, developed a cricket like "chirp", that after cleaning the pulleys & rplacing the belt, turned out to be the idler pulley bearing.
The pulley turned quietly when rotated, but had a ever so slight side to side, looseness/play/wobble.
I could barely feel it & I missed it on my initial check. So if your idler has some miles on it & it's bearings aren't snug, it probably belongs on your suspect list.
You're gonna need more leverage, as already suggested. When I replaced my idler, I also replaced the tensioner and the belt at the same time. I did not have to remove anything else other than the idler and tensioner. However, they were both a pain to do, what with the tight tolerances, I could barely get my arm down there. And the finger cramps. Good luck with that.
