Straight pipe ?
Old Aug 31, 2007 | 03:28 PM
Green_Dually's Avatar
Green_Dually
Straight pipe ?
Ok guys,just straight piped my truck.It sounds great !!!
Just one question,i used those band clamps.But one clamp does not seem to hold good,so can i weld it?
Do i have to unhook the batts?
Thanks guys.
Old Aug 31, 2007 | 03:30 PM
fbilly420's Avatar
fbilly420
I spot welded every connection in my exhaust just put the ground cable on the tail pipe and you should be ok I didnt disconnect my batteries.
Good luck
Billy
Old Aug 31, 2007 | 03:37 PM
ryaneverk2's Avatar
ryaneverk2
Weld away! My muffler delete pipe is welded in place... wasn't planning to reinstall the muffler any time soon.
No need to disconnect the batts, but I suppose it couldn't hurt.
Old Aug 31, 2007 | 03:41 PM
Green_Dually
Is the stock pipe stainless?
Old Aug 31, 2007 | 04:43 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Yes it is. Weld away. I cut my stock pipe off in peices when I installed my new SS 4".
Old Aug 31, 2007 | 05:25 PM
Green_Dually
If its stainless,then i have the Aluminized Exhaust pipe,can they be welded together?
If they can be welded together,what rod will work.
Old Aug 31, 2007 | 11:24 PM
powrstrkn''s Avatar
powrstrkn'
When I had stock exhaust I was able to weld in a delete pipe with a old lincoln 220v buzzbox and a 7018 rod. burned it in one spot then back off the heat and sealed her up.
Old Sep 1, 2007 | 12:07 AM
c00nhunterjoe's Avatar
c00nhunterjoe
weld away. no problem, i love the givadamn avatar
Old Sep 1, 2007 | 06:40 AM
Green_Dually
Thanks guy !!!!!!
