Fixing E-brake cable?
Old Aug 31, 2007 | 11:38 AM
soleam1's Avatar
soleam1
My parking brake is out on my '81 F-250 4X4 and I was wondering if it's a possible fix that I can do myself? Or if it's something best left up to a shop to do? Any help would be greatly appreciated!!
Old Aug 31, 2007 | 12:40 PM
Franklin2's Avatar
Franklin2
You can certainly fix it. Usually the first thing to happen is the cables that go to the rear drums rust and freeze up. Luckily(or not), this happens so often, you can get them pretty cheap at the parts store. You have to take the drums off the rear to replace them though.
After that, everything else is on the outside driver's frame rail, about midway down the frame.
Old Aug 31, 2007 | 04:01 PM
ken's 80's Avatar
ken's 80
The fix IS easy. The hardest part is taking the rear drums apart. If you are going to do this job replace ALL the cables. Through the years they might have stretched out.
Old Aug 31, 2007 | 09:34 PM
fellro86's Avatar
fellro86
I just did this to my 86, both cables for under $30. It isn't that big a deal to get the rear drums off, take the axles out, take the nuts loose, and back tha adjuster down, pull the drum off...
Old Aug 31, 2007 | 09:58 PM
Sport45's Avatar
Sport45
He's got a 150, so the procedure is right except he doesn't have to take the axles out. Sometimes it takes a few whacks with a rubber mallet to get the drums to turn loose.
Old Aug 31, 2007 | 10:01 PM
fellro86's Avatar
fellro86
???? I read 81 F250....
