Confounded
Old Aug 30, 2007 | 06:28 PM
smithbl6's Avatar
smithbl6
Confounded
While I had the rear end of my '74 Ford F100 off the ground replacing the rear brake shoes, I noticed that both rear axles turned freely with the tranny in park. The drive shaft did not turn cause the tranny was in park but why did the axles turn? Does my truck have a faulty rear end?
Old Aug 30, 2007 | 06:33 PM
75F350's Avatar
75F350
Welcome:
It is alright. You simply have an open carrier and one wheel turned one direction while the other one turned the opposite direction. Normal for an open differential.
If you place one tire on the ground and try it again, you may would not be able to turn the wheel.
If it was broken then the truck would not move without making a bunch of noise.
Old Aug 30, 2007 | 06:57 PM
m78's Avatar
m78
I saw a truck start sliding down the road on ice while in park unattended, the left rear was trying to turn backwards
Old Aug 30, 2007 | 11:12 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Thats all normal. If one tire is on pure ice on a hill and the other is on dry pavement one tire will rotate forward and the other will go backwards. Thats one of the reasons why they invented the parking brake and you should use it.
Old Aug 31, 2007 | 06:30 AM
Forge's Avatar
Forge
He specifically said his drive shaft didn't turn, IIRC if ONE wheel is turning, the driveshaft should be also. O.o
Old Aug 31, 2007 | 07:41 AM
psquare7575's Avatar
psquare7575
Not if it's in park, both rear wheels are in the air, and the rear is not trac-loc equipped.
Old Aug 31, 2007 | 11:15 AM
Forge's Avatar
Forge
That's a new one. One spider gear or the other in the differential is always touching the ring gear, thus it should lock up...?
Old Aug 31, 2007 | 12:19 PM
psquare7575
Nope.. wanna see a video of me doing it?
Old Aug 31, 2007 | 12:48 PM
scottie2hottie's Avatar
scottie2hottie
psquare is right. That's the purpose of the spiders, so that the axles can move at a different rate than the ring gear. And spider gears should never be touching the ring gear. If that's the case you might have a problem.
