serpentine belt...
Old Aug 29, 2007 | 06:57 PM
kemerick's Avatar
kemerick
serpentine belt...
My serpentine belts (dual alternator) have been sqweeking for a couple months now. From what I can see without removing the fan guard, the belt looks to be in good condition. Since I can not see nor feel any cracks, is there a fix for my belts?
Since the truck is at 50k miles, is this a normal time frame for a belt replacement? If so, has someone documented it yet, or is it just a tensioner that needs to be loosened? Should I just replace both?
Old Aug 29, 2007 | 11:12 PM
LvTitan's Avatar
LvTitan
have you sprayed it with some belt dressing to see if that helps ?
Old Aug 29, 2007 | 11:41 PM
kemerick's Avatar
kemerick
Is that something sold at chain auto parts stores?
Old Aug 30, 2007 | 05:17 AM
npccpartsman's Avatar
npccpartsman
If you'll check the tech folder I think there is a TSB for squeaking belts and what to do to fix it. I have almost 100K on my original belt with a groove cut in it from a hose clamp and I'm still running it cause I don't wanna fight that monster putting it on. I have a spare belt here just in case though cause not everyone carries it in stock.
Old Aug 30, 2007 | 08:00 AM
kemerick's Avatar
kemerick
I did look first, I just looked again and did a "search this thread" for the word belt and no dice...
Old Aug 30, 2007 | 08:29 AM
69cj's Avatar
69cj
Caution! Most belt dressings make a mess of your pulley's, belt and everything else it comes in contact with.
Old Aug 30, 2007 | 08:56 AM
kemerick's Avatar
kemerick
Okay, I will try not to make it look like Burt Reynolds in the movie Striptease... all lathered up in Vasoline.
