i want to do the constant power on to the switches how do i remove the upfitter switch panel assy without damaging the dash or switch housing assy thanks
That instruction is for pre 2008 models, 08 are in a different place and powered from different place, anyone found how to make them hot all the time on a 2008????
The 2008's are in the middle of the dash now down low, I still can't see anyway to get to them and the relays (which I still have not found) are in a different place from the 2007
the relays are on the left side above the emer brake assy if you look up from there you will see a box that is the relays and the wires are behind the diag link connector under the drivers side facing the seat
i have a 08 f 250 and that is where mine was and it came from the factory with the switches and relays take a look here it explains where they are at and mine was in the same spot
