starter problems
Old Aug 29, 2007 | 10:25 AM
ajordan193's Avatar
ajordan193
starter problems
Well after replacing the starter and the starter solnoid on the fender i'm still having trouble. It will start fine and then every now and then it will screech like its being started again after its been running. Any suggestions on where to go from here?
Old Aug 29, 2007 | 11:36 AM
Neal 97 250's Avatar
Neal 97 250
Sounds like the relay is engaging it again. Maybe check the switch as well I have had on wear out and would move to start position every now and then.
Old Aug 29, 2007 | 01:42 PM
tony mathers's Avatar
tony mathers
neal how do i read my messages? how do i open them?
Old Aug 29, 2007 | 01:54 PM
Cuda_jim's Avatar
Cuda_jim
It could be the ring gear on the flexplate has dead spots in it (worn teeth). Take a good look at the gear by rolling the engine over by hand. Even a new starter can be bad. The gear may not be sliding all the way into the ring gear. The shaft and gear on the starter are very close tolerance and it doesn't take much to make it hang. MOst remans don't get new ones. About the only thing that ever goes wrong with them is the brush plate. I get mine rebuilt by a local guy. I watch him do it in about 10-15 minutes. $50 out the door.
Your PM's are in your user CP (control panel), TOp left side of this page. scroll down to messages.
Old Aug 29, 2007 | 01:55 PM
1997F-350's Avatar
1997F-350
upper right hand corner of your screen it says welcome tony you have _ unread private messages click on it and go from there.
Old Aug 29, 2007 | 02:16 PM
tony mathers
smokin stroke "D"
I went to the corner and clicked on my unread messages but It wont let me read messages?
Old Aug 29, 2007 | 04:18 PM
Cuda_jim's Avatar
Cuda_jim
Send a message to the moderators about your PM's.
